MyArcade Micro Player Broken Joystick/D-Pad Replacement
  1. MyArcade Micro Player Broken Joystick/D-Pad Replacement, Joystick/D-Pad: step 1, image 1 of 3 MyArcade Micro Player Broken Joystick/D-Pad Replacement, Joystick/D-Pad: step 1, image 2 of 3 MyArcade Micro Player Broken Joystick/D-Pad Replacement, Joystick/D-Pad: step 1, image 3 of 3
    • Flip the cabinet over and remove the four 10 mm-long Phillips #2 screws from the back casing of the cabinet.
    • Use a hairdryer to lightly heat the stickers on the side of the cabin.
    • Peel back the sticker far enough to reveal the screws.
    • Remove the three 5 mm-long Phillips screws underneath the stickers of each side of the cabinet.
  2. MyArcade Micro Player Broken Joystick/D-Pad Replacement: step 2, image 1 of 1
    • Carefully pry the back of the cabinet open of the cabinet with your hands.
    • If a sticker on top prevents you from prying it open, remove it to access the cabinet.
  3. MyArcade Micro Player Broken Joystick/D-Pad Replacement: step 3, image 1 of 1
    • Remove the three 10 mm-long Phillips #1 screws holding the motherboard in place.
    • Carefully pry it away to get to the barrier.
    • Do NOT apply too much pressure when removing. The screen can get punctured/damaged.
  4. MyArcade Micro Player Broken Joystick/D-Pad Replacement: step 4, image 1 of 3 MyArcade Micro Player Broken Joystick/D-Pad Replacement: step 4, image 2 of 3 MyArcade Micro Player Broken Joystick/D-Pad Replacement: step 4, image 3 of 3
    • Use the hair dryer to heat the sticker in front. Peel it off slowly to give ease when it comes to removing the barrier.
    • On the edges of the barrier, remove the four 8 mm-long Phillips #1 screws.
  5. MyArcade Micro Player Broken Joystick/D-Pad Replacement: step 5, image 1 of 2 MyArcade Micro Player Broken Joystick/D-Pad Replacement: step 5, image 2 of 2
    • Push the controller container out of the cabinet.
    • Remove the five 7 mm-long Phillips #1 screws located underneath.
  6. MyArcade Micro Player Broken Joystick/D-Pad Replacement: step 6, image 1 of 1
    • Take off the joystick from the panel, and locate the silicone padding.
    • Remove the damaged one and replace it with your new one.
After the last step, follow the process backwards to reassemble the cabinet back in proper condition.
Once done, Congrats! With careful time and proper handling, your cabinet is good to go again! Have fun playing, and thank you for listening and preventing E-Waste.
Emilio Vargas
133 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 22
Past 30 Days: 85
All Time: 469
