Introduction
You will learn how to access your motherboard using the screwdriver and replace your speakers using the spudger.
Slide the back cover down. Lift the back cover up. Pry the battery out with the spudger
  • Slide the back cover down.
  • Lift the back cover up.
  • Pry the battery out with the spudger
Pry the battery out using the spudger
  • Pry the battery out using the spudger
After removing the Battery remove the two screws with a T4 screwdriver.
  • After removing the Battery remove the two screws with a T4 screwdriver.
With the spudger, go around the seam of the phone and pry away the back chassis.
  • With the spudger, go around the seam of the phone and pry away the back chassis.
Using the T5 screwdriver, remove all the four screws shown in the picture.
  • Using the T5 screwdriver, remove all the four screws shown in the picture.
Lift up the motherboard out of the device,
  • Lift up the motherboard out of the device,
Pry the speakers out using the plastic spudger.
  • Pry the speakers out using the plastic spudger.
greg
12 Reputation
5 Guides authored
USF Tampa, Team 7-5, Leahy Fall 2014 Member of USF Tampa, Team 7-5, Leahy Fall 2014
USFT-LEAHY-F14S7G5
3 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 80
