Motorola Moto G7 Plus Battery Removal
  1. Motorola Moto G7 Plus Battery Removal, Remove the Screen: step 1, image 1 of 2 Motorola Moto G7 Plus Battery Removal, Remove the Screen: step 1, image 2 of 2
    • Insert an opening tool pick under the screen, starting at the top of the phone.
    • Slide the pick around the entire perimeter of the display to break the adhesive.
    • There is a cable on the right side of the phone (the side with the volume buttons), which connects the screen to the rest of the phone. Be careful not to damage this cable.
    • Once enough adhesive has been removed, you should be able to separate the screen by gently lifting it from the left side of the phone.
    • While not necessary, applying a gentle heat to the edges of the display with a heat gun or iOpener will weaken the adhesive.
    Dont pry deeper than 3 mm. If you are deeper and just under the glass you will damage the display. The sceen are two layers. Obe witk the veru thin glass and one with a metal frame with display. Yoy want to get under both layers to lift the screen.
    Magnus Tuvendal - Reply
    Correcting autocorrect… Dont pry deeper than 3 mm. If you are deeper and just under the glass you will damage the display. The screen is two layers. One with the very thin glass and one with a metal frame with the lcd-display. Yoy want to get under both layers to lift the screen.
    I don’t have a thermal gun. Here’s what I did. I wrapped my phone in a baggie and an added an oven thermometer into a heating pad and monitored the heat that way. I left it for awhile (to allow all heat to dissipate) and the heat was 189-degrees Fahrenheit. One hour, toasty warm. So I worked with that.
    Harry A - Reply
    So after one hour at 180 degrees Fahrenheit the base already started buckling and removed itself from the screen. So it was easy to remove the base from the screen. There was some rubber thread that I had to remove. Because of that, I understand that now my phone is not water-tight and I need to treat it as such. But the battery replacement went fine and everything is working great after it was all placed back together. I hope to get a few more years out of my G7 plus!
    Harry A - Reply
  2. Motorola Moto G7 Plus Battery Removal, Remove the Display Cable Cover: step 2, image 1 of 2 Motorola Moto G7 Plus Battery Removal, Remove the Display Cable Cover: step 2, image 2 of 2
    • Remove the three 2.7 mm screws that surround the base of the display cable using the Torx T5 screwdriver.
    • Gently remove the metal piece that covers the base of the display cable.
    The plate in mine had a small strip of adhesive, so I had to gently heat the plate+strip after removal to separate them.
    Joe Hopfield - Reply
  3. Motorola Moto G7 Plus Battery Removal: step 3, image 1 of 2 Motorola Moto G7 Plus Battery Removal: step 3, image 2 of 2
    • Use the pointed end of the spudger to lift the metal casing where circled.
  4. Motorola Moto G7 Plus Battery Removal, Separate the Display From the Phone: step 4, image 1 of 2 Motorola Moto G7 Plus Battery Removal, Separate the Display From the Phone: step 4, image 2 of 2
    • Underneath this metal piece is the base of the cable. Use a spudger to vertically lift the connection out of its port.
  5. Motorola Moto G7 Plus Battery Removal, Cut the Black Tape and the Connector Before Removal: step 5, image 1 of 2 Motorola Moto G7 Plus Battery Removal, Cut the Black Tape and the Connector Before Removal: step 5, image 2 of 2
    • Use the blade end of a Halberd Spudger to cut through the two strips of black tape attached to the battery.
    • Use the flat end of a spudger to disconnect the battery from the phone.
  6. Motorola Moto G7 Plus Battery Removal, Remove the Battery: step 6, image 1 of 2 Motorola Moto G7 Plus Battery Removal, Remove the Battery: step 6, image 2 of 2
    • Take the battery out with the flat end of the spudger.
    • Handling batteries can be dangerous. Be very careful not to puncture the battery, as there are dangerous chemicals inside. Physical damage to the battery can cause it to burst into flame and release toxic smoke.
    Ich habe es gerade gemacht. Jetzt geht mein Handy nicht mehr an :(
    Ich weiß nicht ob es nur das Display ist, oder das gesamte Display…
    Tommie - Reply
    Die Batterie war bei mir stark verklebt. Beim herauslösen ist sie "gebrochen" / "geknickt". Habe durchaus Kraft aufwenden müssen, da der Kleber unterhalb sehr zäh war. Wer dieses Problem auch hat, es hilft, mit einem Föhn das Gerät von unten zu erwärmen....
    Rainer Rösch - Reply
    1. Der Ausbau des Akkus wird wesentlich erleichtert, wenn man das Handy auf ein Gel-Pad legt, das zuvor auf 60 - 70 Grad C erwärmt wurde. Noch einfacher ist es das Handy auf die Druckplatte eines 3D Druckers zu legen und hier die Temperatur entsprechend einzustellen. Ein Gel-Pad zwischen Druckplatte und Handy sorgt für einen besseren Wärmeübergang.
    2. Leider fehlt für den Zusammenbau ein Hinweis, wie das Display wieder mit dem Gehäuse am besten verklebt werden soll. 1mm oder 2mm doppelseitiges Klebeband oder Flüssigkleber?
    Hagemi 52 - Reply
15 other people completed this guide.
Jack Browers
377 Reputation
1 Guide authored
Cal Poly, Team S22-G5, Regan Winter 2020 Member of Cal Poly, Team S22-G5, Regan Winter 2020
CPSU-REGAN-W20S22G5
5 Members
17 Guides authored
4 Comments
bricked, the display is not recognized anymore after re-attaching
Mrs Glue - Reply
as an additional information: my phone is bricked, because i severed a connection of the display, which is located at the bottom of the phone - you should only enter the pick up to a depth of ~ 2-3mm at the bottom!
Mrs Glue - Reply
Went as smoothly as possible, thanks very much. Only the glue under the battery was a serious pain in the butt.
Kevin Silbstedt - Reply
Followed the steps, and now my phone is working again. Thanks for the guide.
Gary Campbell - Reply
Past 24 Hours: 10
Past 7 Days: 66
Past 30 Days: 282
All Time: 20,635
