Introduction
This guide will show each detailed step to removing and replacing the battery in the Motorola G7 Play, model number XT1952-3 or XT1952-2. The battery is what keeps the device powered when disconnected from a charger. If the device does not power on or does not hold a charge this can possibly mean that the battery is no longer working. Look out for a swollen or leaking battery. If there is a swollen or leaking battery, be cautious and follow iFixit’s guide on what to do if a battery is swollen.
Before you begin, download the Rescue and Smart Assistant app to backup your device and diagnose whether your problem is software or hardware related.
Insert a paperclip or SIM card eject tool into the small hole in the SIM card tray on the right side of the top edge of the phone.
Press the tool into the hole to eject the tray.
Remove SIM Card Tray.
Use the iFixit pick and the iFixit opening tool to pull the fingerprint scanner off of the back case.
Using an iFixit opener tool, detach the fingerprint sensor and the other 5 cables from the motherboard.
Remove the six 3.2 mm screws from the charging port assembly cover with a Phillips #00 screwdriver.
Remove the cover.
Hello, I’m a new member to IFIXIT and so far your instructions have been crystal clear and easy to follow :) I was wondering if you could inform me on ways I could remove one of the six 3.2 mm screws from the charging port if the screw was stripped? I’m unable to proceed further with your instructions while one of the 3.2 mm screws is stripped.
Using a spudger, break both adhesive strips on the back side of the battery.
This task needed a fair amount of heat, using both a heated pad (ifixit iOpener) and a hot air gun. Insulated gloves makes this step effortless. Heat both ends just near the adhesive until you think it’ s too hot to touch w/o your gloves, then gently pry the battery out using a long plastic spudger. I started on the right side, broke it free, then worked my way left. A hand held hot air gun here is perfect for this because the adhesive, at a good temperature, cleanly peels away from the battery and stays on the phone surface, making it perfect to reuse.
14 other people completed this guide.
6 Comments
I found this useful although I was dismantling a G7 Power. The screws are in different places but most parts and the the battery are the same or similar. Fortunately, though I discovered that steps 8, 9 and 13 were unnecessary. The motherboard and charging boards could be left in place (only the plastic covers had to come off) while the battery was removed.
I successfully changed a battery on a G7 Play. I skipped steps 4, 7, 8, 10, 11, 12, 13, 14, and 15. The instructions for removing the battery are risky. I pried the battery up a little and put constant pressure on it until it came loose which took about 60 seconds. The battery comes with a tiny connector at the end of a ribbon cable. This is plugged into a board, and then the motherboard holds it in place. In general, the phone is not designed for the battery to be replaced which surprised me.
Thank you! I successfully disassembled my G7 Play after an unfortunate dive in a lake to let it completely dry. It's now working as new!
Weird instruction containing a lot of totally superflous steps:
Why removing the fingerprint sensor from backplate?
Why removing the motherboard and charging board?!
Just open the phone, remove the nine screws of the mainboard cover disconnect the battery plug, remove the battery with an old credit card e.g. and some heat from a hair-dryer, replace the battery and than everything vice versa. Done!
BTW: It is totally devious and malicious to let users write their comment just to tell them than afterwards that they have to create an account here before thay can post someting!!
I really did not want or need another accout! What is it good for? Absolutely nothing: Just another source of annoying spam and another stupid password to forget! I do not want to get 'updated' about my posts.
