Shop the Holiday Gift Guide
Motorola Moto G Stylus 5G 2023 Charging Port Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
22
Past 30 Days:
97
All Time:
733
Comments: 0
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 20 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
Motorola Moto G Stylus 5G 2023, Model XT2315, Charging Port Replacement.
If the charging port is damaged, broken or no longer charges a USB-C cord follow this guide to aid in replacement. When disconnecting the silver coaxial cables do not pull coaxial cables out of the device.
Tools
    1. Motorola Moto G Stylus 5G 2023 Charging Port Replacement, Back Cover: step 1, image 1 of 3 Motorola Moto G Stylus 5G 2023 Charging Port Replacement, Back Cover: step 1, image 2 of 3 Motorola Moto G Stylus 5G 2023 Charging Port Replacement, Back Cover: step 1, image 3 of 3
      • Use a SIM eject tool to remove the SIM tray.
      • Gently pull the SIM tray from the left side when the screen is facing upward.
      Ask FixBot
    2. Motorola Moto G Stylus 5G 2023 Charging Port Replacement: step 2, image 1 of 3 Motorola Moto G Stylus 5G 2023 Charging Port Replacement: step 2, image 2 of 3 Motorola Moto G Stylus 5G 2023 Charging Port Replacement: step 2, image 3 of 3
      • Push the tip of the stylus to release the lock.
      • With the screen facing up, remove the stylus from the bottom-right corner of the phone.
      Ask FixBot
    3. Motorola Moto G Stylus 5G 2023 Charging Port Replacement: step 3, image 1 of 3 Motorola Moto G Stylus 5G 2023 Charging Port Replacement: step 3, image 2 of 3 Motorola Moto G Stylus 5G 2023 Charging Port Replacement: step 3, image 3 of 3
      • Place the screen facing downward.
      • Use the small suction cup to create a gap for the opening pick to fit.
      • Place the suction cup near a corner for easier access to insert the opening pick.
      • Insert the opening pick into a corner of the phone and move around the backing to release the adhesive.
      • Pull the backing off of the phone.
      Ask FixBot
    1. Motorola Moto G Stylus 5G 2023 Charging Port Replacement, Speaker: step 4, image 1 of 1
      • Use tweezers to remove the yellow tape.
      Ask FixBot
    2. Motorola Moto G Stylus 5G 2023 Charging Port Replacement: step 5, image 1 of 1
      • Remove the six 3.2 mm screws from the speaker using a Phillips #0 screwdriver.
      Ask FixBot
    3. Motorola Moto G Stylus 5G 2023 Charging Port Replacement: step 6, image 1 of 2 Motorola Moto G Stylus 5G 2023 Charging Port Replacement: step 6, image 2 of 2
      • Peel off the graphite film with tweezers.
      Ask FixBot
    4. Motorola Moto G Stylus 5G 2023 Charging Port Replacement: step 7, image 1 of 3 Motorola Moto G Stylus 5G 2023 Charging Port Replacement: step 7, image 2 of 3 Motorola Moto G Stylus 5G 2023 Charging Port Replacement: step 7, image 3 of 3
      • Pry off the speaker module with the iFixit opening pick.
      Ask FixBot
    1. Motorola Moto G Stylus 5G 2023 Charging Port Replacement, Charging Port: step 8, image 1 of 2 Motorola Moto G Stylus 5G 2023 Charging Port Replacement, Charging Port: step 8, image 2 of 2
      • Disconnect the cable attached to the back panel with tweezers.
      • Disconnect the silver coaxial cables on the right side of the phone.
      Ask FixBot
    2. Motorola Moto G Stylus 5G 2023 Charging Port Replacement: step 9, image 1 of 2 Motorola Moto G Stylus 5G 2023 Charging Port Replacement: step 9, image 2 of 2
      • Remove the silver 2.1 mm screw using a Phillips #0 screwdriver.
      Ask FixBot
    3. Motorola Moto G Stylus 5G 2023 Charging Port Replacement: step 10, image 1 of 2 Motorola Moto G Stylus 5G 2023 Charging Port Replacement: step 10, image 2 of 2
      • Use iFixit tweezers or the opening pick to find an opening and remove the entire charging port.
      Ask FixBot
3 other people completed this guide.
Author
with
Daniel Osorio Ospina
389 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 22
Past 30 Days: 97
All Time: 733
