Introduction
Full Device Name: Motorola Moto Stylus 4G (2023)
Model Number: XT2317-2
Alternate Name: Moto Stylus 4G (2023)
Objective: This guide aims to provide step-by-step instructions for replacing the charging port in the Motorola Moto Stylus 4G (2023).
About the Charging Port: This device sports a Type-C USB dock connector charging port.
Device Symptoms: If the phone is not charging consistently or at all, refer to this guide to replace the charging port.
Insert an opening pick under the edge of the case and slide it around the edges.
Separate the back panel from the rest of the phone.
Use the opening pick along the edges to separate the camera lens glass from the board. If you begin to pry where the picture indicates, you will only get the top plastic and it will peal away from the paint. Instead begin at the gap in the lower left hand corner where there is a space between the actual frame that contains the lenses and the phone.
Unplug the two antenna heads and main ribbon connector cable from the charging port board.
