Motorola Moto G Stylus (2021) Main Board Replacement
  1. Motorola Moto G Stylus (2021) Main Board Replacement, Rear Case: step 1, image 1 of 3 Motorola Moto G Stylus (2021) Main Board Replacement, Rear Case: step 1, image 2 of 3 Motorola Moto G Stylus (2021) Main Board Replacement, Rear Case: step 1, image 3 of 3
    • Push a SIM tray ejector into the hole.
    • Remove the SIM card and tray.
    Ask FixBot
  2. Motorola Moto G Stylus (2021) Main Board Replacement: step 2, image 1 of 2 Motorola Moto G Stylus (2021) Main Board Replacement: step 2, image 2 of 2
    • Before you begin, discharge the battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your phone and disconnect the charger and any peripheries before beginning disassembly.
    • Lay the phone face down.
    • Heat an iOpener and apply it to the rear case.
    • Alternatively, use a hair dryer to heat the rear case until it's almost too hot to touch.
    Ask FixBot
  3. Motorola Moto G Stylus (2021) Main Board Replacement: step 3, image 1 of 2 Motorola Moto G Stylus (2021) Main Board Replacement: step 3, image 2 of 2
    • Insert an opening tool into the seam between the rear case and chassis.
    • Once you create a gap, insert an opening pick a couple of millimeters into the gap.
    • Slide the opening pick around the entire perimeter to sever the adhesive that secures the rear case.
    • If you feel excessive resistance, reheat the problem area(s).
    • Remove the rear case.
    Ask FixBot
  4. Motorola Moto G Stylus (2021) Main Board Replacement, Main Board: step 4, image 1 of 2 Motorola Moto G Stylus (2021) Main Board Replacement, Main Board: step 4, image 2 of 2
    • Use an opening tool to lift and remove the midframe.
    Ask FixBot
  5. Motorola Moto G Stylus (2021) Main Board Replacement: step 5, image 1 of 1
    • You may need to use your heating device again to remove glue from covering the screws.
    • Use a T4 Torx screwdriver to remove all eleven 3.2 mm screws securing the midframe.
    Ask FixBot
  6. Motorola Moto G Stylus (2021) Main Board Replacement: step 6, image 1 of 2 Motorola Moto G Stylus (2021) Main Board Replacement: step 6, image 2 of 2
    Ask FixBot
  7. Motorola Moto G Stylus (2021) Main Board Replacement: step 7, image 1 of 1
    • Remove the black tape covering the connectors.
    • Use an opening tool to lift and disconnect the four press connectors.
    • Use an opening tool to lift and disconnect the two antenna cables connectors.
    Ask FixBot
  8. Motorola Moto G Stylus (2021) Main Board Replacement: step 8, image 1 of 2 Motorola Moto G Stylus (2021) Main Board Replacement: step 8, image 2 of 2
    • Use an opening tool to lift and disconnector the front camera press connector.
    • Remove the front camera.
    Ask FixBot
  9. Motorola Moto G Stylus (2021) Main Board Replacement: step 9, image 1 of 2 Motorola Moto G Stylus (2021) Main Board Replacement: step 9, image 2 of 2
    • Use a T4 Torx screwdriver to remove the two 3 mm screws securing the main board.
    Ask FixBot
  10. Motorola Moto G Stylus (2021) Main Board Replacement: step 10, image 1 of 2 Motorola Moto G Stylus (2021) Main Board Replacement: step 10, image 2 of 2
    • Use a spudger to an edge of the main board.
    • Lift and remove the motherboard.
    Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Connor Bassolino
23,157 Reputation
111 Guides authored
iFixit Member of iFixit
Staff
122 Members
25,805 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 40
All Time: 415
