Shop the Holiday Gift Guide
Motorola Moto G 1st Generation Headphone Jack Replacement
Views: 3K
View statistics:
Past 24 Hours:
3
Past 7 Days:
17
Past 30 Days:
80
All Time:
2,958
Comments: 0
Go to guide comments
Completed: 0
Favorites: 5
5 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 - 20 minutes
Difficulty: Moderate
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
    1. Motorola Moto G 1st Generation Headphone Jack Replacement, Rear Panel: step 1, image 1 of 3 Motorola Moto G 1st Generation Headphone Jack Replacement, Rear Panel: step 1, image 2 of 3 Motorola Moto G 1st Generation Headphone Jack Replacement, Rear Panel: step 1, image 3 of 3
      • Before you start following any of the steps of this guide, completely turn the device off.
      • Take the plastic back cover off by either using a plastic Pry tool or simply using your hands. Start from the bottom by the charging port
      Ask FixBot
    2. Motorola Moto G 1st Generation Headphone Jack Replacement, Removing the Screws: step 2, image 1 of 1
      • Unscrew the 3.5mm screws, total of 14, located on the back protective cover by using a T5 Torx screwdriver.
      Ask FixBot
    3. Motorola Moto G 1st Generation Headphone Jack Replacement, Removing the Battery Cover: step 3, image 1 of 2 Motorola Moto G 1st Generation Headphone Jack Replacement, Removing the Battery Cover: step 3, image 2 of 2
      • Use a plastic opening tool to remove the protective cover.
      • Carefully work the plastic tool around all the edges of the phone.
      • The protective cover holds the Volume and the Home buttons which might fall off the assembly when the cover is removed.
      Ask FixBot
    1. Motorola Moto G 1st Generation Headphone Jack Replacement, Removing the Headphone Jack: step 4, image 1 of 3 Motorola Moto G 1st Generation Headphone Jack Replacement, Removing the Headphone Jack: step 4, image 2 of 3 Motorola Moto G 1st Generation Headphone Jack Replacement, Removing the Headphone Jack: step 4, image 3 of 3
      • Use the plastic opening tool to remove the Headphone Jack from the protective cover and replace it.
      Ask FixBot
Author
with
Radostin Lobodov
2,946 Reputation
6 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 17
Past 30 Days: 80
All Time: 2,958
