Fix Your Stuff
Right to Repair
Store
Introduction
Use this guide to replace a broken or defective LCD and digitizer in your Motorola Moto E4 (XT1762).
This guide shows you how to replace the display and digitizer. Make sure you have the correct part before starting this guide.
You may need replacement adhesive to reattach components during reassembly.
For replacing the screen assembly including the frame use this guide.
  1. Power off your phone before beginning disassembly. Insert a fingernail, or spudger, into the notch on the bottom right corner to start separating the phone unit from the back cover. Move to the bottom left corner to pry the phone out of the back cover.
    • Power off your phone before beginning disassembly.
    • Insert a fingernail, or spudger, into the notch on the bottom right corner to start separating the phone unit from the back cover.
    • Move to the bottom left corner to pry the phone out of the back cover.
    I hve a question not a comment. I would like to know if this battery model will work in my moto E 4 Model # XT1775. Thank you.
    Gamaliel Gooding - Reply
    This models battery is compatible with the Moto G4 Play, E4, and E5 Play:
    Motorola Moto G4 Play, E4, and E5 Play Battery
    You’re probably looking for the Moto E4 Plus (XT1775) battery:
    Moto E4 Plus Battery
    Tobias Isakeit -
    My US XT1768 did not have a notch here. I used my fingernails to pop the back cover off. Also, I followed this guide to successfully repair my US XT1768 in about 2 hrs. I’ve added a few comments below to point out the slight differences I found along the way
    Tom Bartol - Reply
  2. Lift the phone out of the back cover. Lift the phone out of the back cover.
    • Lift the phone out of the back cover.
  3. Use a fingernail or spudger to pry at the notch at the bottom end of the battery. Lever the battery out of its recess and remove it. Lever the battery out of its recess and remove it.
    • Use a fingernail or spudger to pry at the notch at the bottom end of the battery.
    • Lever the battery out of its recess and remove it.
  4. Remove the six 3.3 mm long Phillips #00 screws.
    • Remove the six 3.3 mm long Phillips #00 screws.
  5. Insert an opening pick between the loudspeaker and the frame to pry it up by twisting the opening pick. Remove the loudspeaker unit.
    • Insert an opening pick between the loudspeaker and the frame to pry it up by twisting the opening pick.
    • Remove the loudspeaker unit.
  6. Remove the seven 3.3 mm Phillips #00 screws.
    • Remove the seven 3.3 mm Phillips #00 screws.
    My US XT1768 has 9 screws
    Tom Bartol - Reply
  7. Insert an opening pick between the cover and the motherboard at the bottom right corner. Slide the opening pick upwards to open the plastic clips.
    • Insert an opening pick between the cover and the motherboard at the bottom right corner.
    • Slide the opening pick upwards to open the plastic clips.
    It was a bit tricky to pop the cover on my US XT1768 as there is a big tab near the battery compartment. Don’t force this tab. Instead, keep working on snapping the tabs loose on the headphone jack side of the cover. This worked for me.
    Tom Bartol - Reply
  8. Insert an opening pick between the cover and the motherboard at the bottom left corner. Slide the opening pick upwards to open the plastic clips.
    • Insert an opening pick between the cover and the motherboard at the bottom left corner.
    • Pry up the motherboard cover by twisting the opening pick.
  9. Remove the motherboard cover.
    • Remove the motherboard cover.
  10. Use a pair of tweezers to peel off the yellow tape of the ZIF connector located on the left of the motherboard. Use a pair of tweezers to peel off the yellow tape of the ZIF connector located on the left of the motherboard.
    • Use a pair of tweezers to peel off the yellow tape of the ZIF connector located on the left of the motherboard.
    My US XT1768 did not have the yellow tape.
    Tom Bartol - Reply
  11. Use the edge of a spudger to open the black flap of the ZIF connector. Use the edge of a spudger to open the black flap of the ZIF connector.
    • Use the edge of a spudger to open the black flap of the ZIF connector.
  12. Slide the volume button flex cable out of the ZIF connector to disconnect it. Slide the volume button flex cable out of the ZIF connector to disconnect it.
    • Slide the volume button flex cable out of the ZIF connector to disconnect it.
  13. Use a pair of tweezers to pry up and disconnect the antenna cable located on the left of the motherboard. Fold the antenna cable out of the way.
    • Use a pair of tweezers to pry up and disconnect the antenna cable located on the left of the motherboard.
    • Fold the antenna cable out of the way.
    My US XT1768 has the antenna cable on the opposite side of the unit.
    Tom Bartol - Reply
  14. Use the edge of a spudger to pry up and disconnect the display flex cable located on the bottom left of the motherboard. Use the edge of a spudger to pry up and disconnect the display flex cable located on the bottom left of the motherboard.
    • Use the edge of a spudger to pry up and disconnect the display flex cable located on the bottom left of the motherboard.
  15. Remove the two 2.9 mm long Phillips #00 screws securing the motherboard.
    • Remove the two 2.9 mm long Phillips #00 screws securing the motherboard.
  16. Don't try to remove the motherboard all the way yet. The interconnect flex cable is still connected to its rear side. Use a spudger to carefully lift the motherboard from the top and fold it towards the battery compartment.
    • Don't try to remove the motherboard all the way yet. The interconnect flex cable is still connected to its rear side.
    • Use a spudger to carefully lift the motherboard from the top and fold it towards the battery compartment.
    • Be careful not to damage any components underneath the motherboard.
  17. Use the edge of a spudger to disconnect the interconnect cable from the motherboard. Remove the motherboard. Remove the motherboard.
    • Use the edge of a spudger to disconnect the interconnect cable from the motherboard.
    • Remove the motherboard.
  18. Use a pair of tweezers to pry up and disconnect the antenna cable. Use a pair of tweezers to pry up and disconnect the antenna cable.
    • Use a pair of tweezers to pry up and disconnect the antenna cable.
  19. Use the edge of a spudger to pry up and disconnect the interconnect flex cable. Use the edge of a spudger to pry up and disconnect the interconnect flex cable.
    • Use the edge of a spudger to pry up and disconnect the interconnect flex cable.
  20. Use the edge of a spudger to pry up and disconnect the fingerprint sensor flex cable. Use the edge of a spudger to pry up and disconnect the fingerprint sensor flex cable.
    • Use the edge of a spudger to pry up and disconnect the fingerprint sensor flex cable.
  21. Remove the 2.9 mm long Phillips #00 screw securing the daughterboard.
    • Remove the 2.9 mm long Phillips #00 screw securing the daughterboard.
    My US XT1768 has two screws securing the daughterboard and the board spans the full width of the case.
    Tom Bartol - Reply
  22. Pry under the bottom end of the charging board and lift it upwards. Remove the charging board.
    • Pry under the bottom end of the charging board and lift it upwards.
    • Remove the charging board.
    My US XT1768 has the vibrator motor not mounted on the daughterboard. Instead, the vibrator is connected by wires to the board and is secured loosely secured in a small slot in the case. Just use the tip of the spudger to pop it up out of this small slot a little at a time as you also pop of the daughterboard. Be careful not to pull on the wires.
    Tom Bartol - Reply
  23. Prepare an iOpener and apply it to the edges of the display for at least two minutes to loosen the adhesive beneath.
    • Prepare an iOpener and apply it to the edges of the display for at least two minutes to loosen the adhesive beneath.
  24. Once the screen is warm to the touch, apply a suction cup to the upper area of the phone right under the earpiece speaker. If the phone's screen is cracked, the suction cup may not stick. Try lifting it with strong tape, or superglue the suction cup in place and allow it to cure so you can proceed. Pull up the suction cup, and insert an opening pick under the display.
    • Once the screen is warm to the touch, apply a suction cup to the upper area of the phone right under the earpiece speaker.
    • If the phone's screen is cracked, the suction cup may not stick. Try lifting it with strong tape, or superglue the suction cup in place and allow it to cure so you can proceed.
    • Pull up the suction cup, and insert an opening pick under the display.
    • Slide the opening pick to the top left corner of the phone to cut the adhesive.
  25. Insert a second opening pick. Slide it to the top right corner.
    • Insert a second opening pick.
    • Slide it to the top right corner.
  26. If cutting becomes too difficult, reheat and reapply the iOpener. Slide the opening pick from the top right corner along the edge of the phone to cut the adhesive. Make sure you get under the display unit and not just between the LCD and the digitizer on the front glass when cutting the adhesive.
    • If cutting becomes too difficult, reheat and reapply the iOpener.
    • Slide the opening pick from the top right corner along the edge of the phone to cut the adhesive.
    • Make sure you get under the display unit and not just between the LCD and the digitizer on the front glass when cutting the adhesive.
    • Slide the opening pick around the bottom right corner.
  27. Slide the opening pick along the bottom edge of the phone and cut the adhesive. In the middle where the home button is only use the very tip of the opening pick to not damage it. In the middle where the home button is only use the very tip of the opening pick to not damage it.
    • Slide the opening pick along the bottom edge of the phone and cut the adhesive.
    • In the middle where the home button is only use the very tip of the opening pick to not damage it.
  28. Repeat the previous heating and cutting procedure on the left edge of the phone to cut the remaining adhesive. Try not to remove the display all the way yet. The fingerprint and display flex cables are still threaded through and may stick to the frame. Try not to remove the display all the way yet. The fingerprint and display flex cables are still threaded through and may stick to the frame.
    • Repeat the previous heating and cutting procedure on the left edge of the phone to cut the remaining adhesive.
    • Try not to remove the display all the way yet. The fingerprint and display flex cables are still threaded through and may stick to the frame.
  29. Use a pair of tweezers to peel both display flex cables off the frame. They are located on the bottom left and at the top of the motherboard. Use a pair of tweezers to peel both display flex cables off the frame. They are located on the bottom left and at the top of the motherboard.
    • Use a pair of tweezers to peel both display flex cables off the frame. They are located on the bottom left and at the top of the motherboard.
  30. Carefully thread both display cables through their gaps in the frame. Carefully thread both display cables through their gaps in the frame.
    • Carefully thread both display cables through their gaps in the frame.
  31. Make sure the fingerprint sensor flex cable does not stick to the frame. If so, peel it loose with a pair of tweezers.
    • Make sure the fingerprint sensor flex cable does not stick to the frame. If so, peel it loose with a pair of tweezers.
  32. Carefully thread the fingerprint sensor cable at the bottom through its gap in the frame. Carefully thread the fingerprint sensor cable at the bottom through its gap in the frame.
    • Carefully thread the fingerprint sensor cable at the bottom through its gap in the frame.
  33. Remove the LCD and digitizer unit.
    • Remove the LCD and digitizer unit.
    • Remove any remaining adhesive from the frame, and clean the glued areas with isopropyl alcohol and a lint-free cloth.
  34. In case you're replacing a broken screen and the replacement screen already includes the home button, skip the following steps.
    • In case you're replacing a broken screen and the replacement screen already includes the home button, skip the following steps.
    • Apply an iOpener for about one minute to the bottom end of the display where the home button is located.
  35. Use your fingertip to push the home button from the front through the display. Remove the home button. Remove the home button.
    • Use your fingertip to push the home button from the front through the display.
    • Remove the home button.
If possible, turn on your phone and test your repair before installing new adhesive and resealing the phone.
The best way to secure the new screen is with a sheet of custom-cut double-sided tape. If the replacement part does not come with adhesive preinstalled apply tape to the back of the screen, then carefully feed the display cable through the frame. Align the screen and press it into place.
4 other people completed this guide.
Dominik Schnabelrauch
85,654 Reputation
365 Guides authored
iFixit Member of iFixit
Community
135 Members
14,996 Guides authored
2 Comments
ottima guida… un’osservazione: a volte può capitare che acquistando un LCD+ DIGITIZER nuovo questi due non siano collegati. accertarsi prima di inserirlo nel frame.
dualcore - Reply
Nicely done guide! Thank you!
Daniel Walton - Reply
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 45
All Time: 2,538
