Introduction
Use this guide to replace the motherboard in your device.
Use your finger or the tip of a spudger to compress the pin securing the watch band.
With the pin compressed, remove the watch band.
Insert an opening tool to into the small notch next to the microphone hole.
Slide the opening tool around the perimeter of the trim ring while prying up slightly to slice through the adhesive securing the ring to the watch.
Remove the trim ring.
Use an opening tool to slowly pry the button trim ring straight up.
Use a small pin spanner to unscrew the button.
Remove the button.
Leave the ring from the previous step partially in and use it as a wrench on the actual nut.
It's a great idea in theory, but how do you grip the ring to turn it?
You are my hero! Heating and trying to turn it using tweezers didn't work, but this did.
Brilliant suggestion many thanks.
How do you get the ring to do that? Having a hard time with this step 😅
Note that the recommended Spanner Set on this page is too big for this job, None of the "pins" fit.
Ik heb werkelijk geen idee hoe ik die pijn los krijg. Kan dit vergroot worden getoond op de foto? Eventueel met meer uitleg (welke kant draai je op, wat draai je precies). Verder super blij met deze uitleg, maar ik loop dus helaas vast.
While holding the outer case steady, twist the inner watch assembly clockwise until it stops.
Use a fingernail or opening tool to pry the plastic lower assembly away from the display assembly.
Use tweezers to remove the small rubber strip between the battery and the display ZIF connector.
What if the rubber strip tears? What is it’s purpose?
This and the following step are unnecessary.
Adding another comment not to do this step or the subsequent ones for removing the display connector. They are unnecessary, and the parts are fragile. Otherwise an excellent guide.
Use a spudger to lift the locking flap on the display ZIF connector.
I cannot reattach my display cable and my watch is now useless. Really angry as this step IS NOT NECESSARY. You can easily change the battery without doing this. DON’T DO THIS.
Agreed - this should be removed from instructions. It is just destructive. Wish I had seen these comments before I did this.
Agree with all the above. AND I am replacing the display so I MUST attach the new cable and cannot for the life of me figure out this ZIFF connector. It is a mystery.
Use the flat end of a spudger to gently pry the battery out of the case.
It mentions that the glue is to be replaced, but it does not explain what glue to use and how to use it.
Elmer’s rubber cement worked for me. I put some on the bottom of the battery and on the ring that had the glue softened in the first steps. It has held well so far, maybe 3 weeks or so.
At this point, I would connect the new battery and re-assemble the watch (without the crown and ring) and test the battery and watch by trying to charge it. This way, if it doesn’t charge, you don’t have to do a full disassembly to figure things out. Once the watch is charged to 100%, you can re-assemble. Also, it took about a minute before the new battery looked like it was charging (while on the charger) so give it some time.
Something not mentioned here is that the gold crown trim piece has 3 long and 3 short prongs. You need to align these to the matching sized holes in order for it to go in correctly. If you don’t, the trim piece will not go in properly. Before concluding your work, ensure that pressing the crown results in going to the menus (to verify it’s screwed in enough and functional).
Remove the battery.
Completed, but have a spot on the screen now. I have a feeling that taking this watch apart has killed all the water resistance and I’ll be in the market for a new watch very soon. Everything about this repair feels like a moonshot. Frustrating. it’s just a battery. they should be easily replaceable. Full stop.
Agree with the first comment. Also, does the copper foil that is on the old battery need to be installed on the new battery?
Detach the copper ribbon connecting the motherboard and the display.
Use the spudger to separate the motherboard casing from the rear housing.
Do not follow this it makes you break the piece that holds the button in. I broke my watch following this. I figure it out afterward but too late, the button and its surrounding unscrews out.
I screwed up my touch screen on this step. Not sure how the ribbon for the battery is removed.
