Introduction
This guide will show you how to replace the screen as your may be scratched or cracked. This process does require tools, a heat gun in particular. Be careful to not heat your screen for too long as it can damage the electronics.
Remove the circled screws using a T-5 torques. These screws will be 4.3 millimeters in length.
Remove the circled screws using a T-5 torques.. These screws should be 5.8 millimeters in length.
Using a plastic opening tool, snap open the phone. It should separate into a front piece with the hardware and a plastic backing.
Using a spudger, remove the camera. Lift up the motherboard and slide the spudger under the camera.
