Introduction
Use this guide to replace the dual LED flash board in your Motorola Droid Turbo.
Prepare an iOpener and lay it over the rear case to soften the adhesive on securing the rear case to the phone.
Use a plastic opening tool to pry the rear case off of the rest of the device.
Remove the rear case.
I had to go around the case, starting on the non-button side, around the top and then the other side. This, unfortunately, pulled on the rear case, pressed the power button and turned the device back on. I would suggest starting on the button side and going around.
Use a Jimmy to separate the dual LED flash board from the rear case.
What I meant to say was great job! Also I have a question about the adhesive pads holding the flash on. Shouldn't they be replaced as well? My flash wasn't working so I took the back off and cleaned the contacts and put it back together. It worked fine for a couple of days and went back to only blinking. The pads seem to be letting the flash part move with the chop motion to activate the flashlight,
One Comment
Gostaria se possível alguem tenha o manual de serviço do Moto maxx XT 1225 ou 1254. Porf favor , ddani8260@gmail.com
This di not work; I had to use a blow dryer.
Caroline Downie - Reply
