Motorola Atrix HD Battery Replacement
  1. Motorola Atrix HD Battery Replacement, Battery: step 1, image 1 of 3 Motorola Atrix HD Battery Replacement, Battery: step 1, image 2 of 3 Motorola Atrix HD Battery Replacement, Battery: step 1, image 3 of 3
    • Before disassembling the phone, remove the SIM card and the MICRO-SD card, if equipped.
    • Begin taking apart the device by prying apart the back cover from the assembly using the plastic opening tool.
    • Continue working around the edge of the phone using the plastic opening tool.
    • When all the edges have been lifted apart, use your hands or plastic opening tool to peel the back plate from the battery. There are small adhesive strips between the back cover and the battery, so take care not to crack the back cover while prying open.
  2. Motorola Atrix HD Battery Replacement: step 2, image 1 of 1
    • The adhesive strips are shown in the orange boxes. Be sure not to use too much force to pull off the back cover, or you may risk snapping the back cover.
  3. Motorola Atrix HD Battery Replacement: step 3, image 1 of 3 Motorola Atrix HD Battery Replacement: step 3, image 2 of 3 Motorola Atrix HD Battery Replacement: step 3, image 3 of 3
    • Remove the red rubber screw cover with a pair of tweezers
  4. Motorola Atrix HD Battery Replacement: step 4, image 1 of 2 Motorola Atrix HD Battery Replacement: step 4, image 2 of 2
    • Use the T-5 Torx bit to remove the two silver 3.3 mm screws with integrated washers.
  5. Motorola Atrix HD Battery Replacement: step 5, image 1 of 1
    • Lift the battery leads to the upward position. The ribbon cable is very thin, be gentle.
  6. Motorola Atrix HD Battery Replacement: step 6, image 1 of 3 Motorola Atrix HD Battery Replacement: step 6, image 2 of 3 Motorola Atrix HD Battery Replacement: step 6, image 3 of 3
    • Use the plastic opening tool around the edges to loosen the battery.
    • Once the battery is loose, carefully lift from the bottom edge and remove the battery.
  7. Motorola Atrix HD Battery Replacement: step 7, image 1 of 1
    • The battery may now be removed.
4 other people completed this guide.
Bradley Hinckley
561 Reputation
2 Guides authored
UMass Dartmouth, Team 1-8, Miles Fall 2015 Member of UMass Dartmouth, Team 1-8, Miles Fall 2015
UMASSD-MILES-F15S1G8
3 Members
10 Guides authored
One Comment
How do you calibrate it then? Lights up green dot, charges, won't work! Multi tester shows full power.
jvandeputte - Reply
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 3,232
