Introduction
This guide will enable you to remove the antenna in a Motorola Atrix 4G.
Insert a spudger or plastic opening tool into the small notch at the base of the battery.
Lift the battery out of the phone.
Remove the four 5.0 mm T5 Torx screws from the corners of the phone.
Remove the four 5.5 mm T5 Torx screws from the back of the phone.
Remove the back case of the phone by gently lifting the tabs located on top of the phone near the lock button.
Use the case opener or spudger in these small areas because the plastic tabs can be easily broken.
Lift the tabs located on the bottom of the phone to continue removing the back cover.
Slide an opening tool between the gap from the back of the case to the front.
After separating the sides, make sure there is a noticeable gap between the back case and the rest of the phone.
After detaching the tabs and sliding down the sides, there should be a noticeable gap between the front and back cases.
Carefully separate the back case from the rest of the phone by lifting it away from the phone.
Ease the antenna from out of its guide along the side of the phone
Once the antenna is detached, remove the back case and the antenna from the phone
