Motorola C168 Screen Replacement
  1. Motorola C168 Screen Replacement, Battery: step 1, image 1 of 2 Motorola C168 Screen Replacement, Battery: step 1, image 2 of 2
    • Turn the phone so its back is facing you.
    • Press the release button on the back cover, while simultaneously pulling the cover down.
    • Remove the back cover.
  2. Motorola C168 Screen Replacement: step 2, image 1 of 2 Motorola C168 Screen Replacement: step 2, image 2 of 2
    • Pinch the sides of the bottom of the battery and pull upward.
  3. Motorola C168 Screen Replacement, SIM Card: step 3, image 1 of 2 Motorola C168 Screen Replacement, SIM Card: step 3, image 2 of 2
    • Press and slide the SIM card down.
    • Remove the SIM card.
  4. Motorola C168 Screen Replacement, Front Panel: step 4, image 1 of 2 Motorola C168 Screen Replacement, Front Panel: step 4, image 2 of 2
    • Orient the phone so its back is facing you.
    • Using a Torx T-4 screwdriver, carefully remove the 4 screws located at the corners of the phone.
    • Note: If you are using iFixit's screwdriver toolkit, look for the smallest T-screwbit.
  5. Motorola C168 Screen Replacement: step 5, image 1 of 2 Motorola C168 Screen Replacement: step 5, image 2 of 2
    Tool used on this step:
    Spudger
    $3.99
    Buy
    • Lodge a spudger in between the front panel and the main frame of the phone.
    • Using a good amount of torque, pry the front panel from the phone.
  6. Motorola C168 Screen Replacement, Screen: step 6, image 1 of 2 Motorola C168 Screen Replacement, Screen: step 6, image 2 of 2
    Spudger
    $3.99
    Buy
    • Place the phone on its back.
    • Insert the spudger at the bottom of the phone, between the phone's frame and the circuit board.
    • Remove the circuit board from the frame.
    • Removing the board takes more force than you would expect.
  7. Motorola C168 Screen Replacement: step 7, image 1 of 2 Motorola C168 Screen Replacement: step 7, image 2 of 2
    • Bend the screen clamps outward so they are no longer underneath the circuit board.
    • Pull the screen encasing away from the circuit board.
    • Caution: The screen-to-phone interface will still be connected.
  8. Motorola C168 Screen Replacement: step 8, image 1 of 2 Motorola C168 Screen Replacement: step 8, image 2 of 2
    • Unplug the screen-to-phone interface.
    • Remove the screen from its encasing by pushing it out.
Christopher Wu
37 Reputation
3 Guides authored
Cal Poly, Team 12-40, Regan Spring 2012 Member of Cal Poly, Team 12-40, Regan Spring 2012
CPSU-REGAN-S12S12G40
4 Members
8 Guides authored
2 Comments
motorola c168 network not working problem. how to repair network problem?
sattar - Reply
pls tell me?
sattar - Reply
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 5
All Time: 1,363
