Moto C Daughterboard Cover Replacement
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. Moto C Daughterboard Cover Replacement, Back Cover: step 1, image 1 of 3 Moto C Daughterboard Cover Replacement, Back Cover: step 1, image 2 of 3 Moto C Daughterboard Cover Replacement, Back Cover: step 1, image 3 of 3
    • Power off your phone before beginning disassembly.
    • Insert a thumbnail, or spudger, into the notch on the bottom right corner to start separating the phone unit from the back cover.
    • Move it to the bottom left corner and pry the phone unit out of the back cover until you can get a good grip.
  2. Moto C Daughterboard Cover Replacement: step 2, image 1 of 2 Moto C Daughterboard Cover Replacement: step 2, image 2 of 2
    • Lift the phone out of the back cover.
  3. Moto C Daughterboard Cover Replacement, Battery: step 3, image 1 of 3 Moto C Daughterboard Cover Replacement, Battery: step 3, image 2 of 3 Moto C Daughterboard Cover Replacement, Battery: step 3, image 3 of 3
    • Use a finger or spudger to lever the battery out of its recess and remove it.
  4. Moto C Daughterboard Cover Replacement, Daughterboard Cover: step 4, image 1 of 1
    • Remove the four 3.5 mm long Torx T5 screws.
    • Some screws might be covered with stickers.
  5. Moto C Daughterboard Cover Replacement: step 5, image 1 of 3 Moto C Daughterboard Cover Replacement: step 5, image 2 of 3 Moto C Daughterboard Cover Replacement: step 5, image 3 of 3
    • Apply the edge of an opening pick to the bottom right corner under the daughterboard cover.
    • Twist the opening pick to open the plastic clamps of the daughterboard cover.
    • Slide the opening pick to the left and pry it upwards until you can get a good grip on the daughterboard cover.
  6. Moto C Daughterboard Cover Replacement: step 6, image 1 of 1
    • Remove the daughterboard cover.
Dominik Schnabelrauch
202,516 Reputation
682 Guides authored
iFixit Member of iFixit
Staff
135 Members
16,718 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 8
