Introduction
If your screen cracks or one of the pixels no longer functions correctly, you may need to replace the display screen. This guide will take you through the process of removing and replacing the display screen of the LE1600.
Slide and hold the switch by the fan vent to the unlocked position. Firmly grasp the battery and pull away from tablet.
Unscrew hard drive panel using a Phillips head #1 screwdriver.
(Our device was not given to us with a hard drive or a hard drive panel)
To disconnect the three white ribbon cables on the side closest to the hard drive connector, pull the white plastic tabs.
To disconnect the remaining ribbon cables, pull the plastic connectors away from their connections.
Using a spudger, press in the five tabs on the side where the battery was.
This should separate the two halves of the device. Carefully set the side with the motherboard off to the side.
With a Phillips #1 screwdriver, unscrew the three 4mm screws holding the display bracket on the back side of the front buttons.
On the bracket behind the fingerprint scanner, unscrew the two 4mm screws holding it to the display with a Phillips #1 screwdriver.
Fold away right bracket from display.
