Introduction
If your Monster DNA headphones are playing noise out of only one side then it is likely that there is a loose wire and this will need to be soldered. This happens frequently because small tensions on the wire can loosen the solder joints easily. To do so, you must disassemble the earpiece and reattach the wires.
  1. Take off the ear cushions by pulling on the sides.
    • Take off the ear cushions by pulling on the sides.
  2. Use a Phillips #2 screwdriver to unscrew the three 5mm screws that secure the speaker cover.
    • Use a Phillips #2 screwdriver to unscrew the three 5mm screws that secure the speaker cover.
  3. Free shipping on all orders over $100 or containing a Pro Tech Toolkit!
    Browse Our Store
  4. Use a plastic opening tool or a metal spudger to pry off the plate
    • Use a plastic opening tool or a metal spudger to pry off the plate
    • Be careful as too much force may cause damage to your headphones.
  5. Once the loose wire or wires are located on the back of the speaker,  use a soldering iron to attach the loose wire back onto the speaker.
    • Once the loose wire or wires are located on the back of the speaker, use a soldering iron to attach the loose wire back onto the speaker.
Kevin Costello
213 Reputation
2 Guides authored
One Comment
any ways on being able to know which side its on in particular without having to open both sides?
Finnlay Worchurst - Reply
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 49
All Time: 1,665
