Model-V2945Z Cordless Shark Floor and Carpet Sweeper-Rotating Brush Replacement
  1. Model-V2945Z Cordless Shark Floor and Carpet Sweeper-Rotating Brush Replacement, Replacing a Rotating Brush: step 1, image 1 of 1
    • Turn vacuum off before starting the fix.
    • Power-off vacuum by pressing the button on the left-rear side of vacuum until the red light is off.
    • Lay vacuum down with handle lying flat on the floor.
  2. Model-V2945Z Cordless Shark Floor and Carpet Sweeper-Rotating Brush Replacement: step 2, image 1 of 2 Model-V2945Z Cordless Shark Floor and Carpet Sweeper-Rotating Brush Replacement: step 2, image 2 of 2
    • Remove and empty dust tray; make sure to clean any debris built up.
    • Lay vacuum up-side-down, locating the broken brush.
  3. Model-V2945Z Cordless Shark Floor and Carpet Sweeper-Rotating Brush Replacement: step 3, image 1 of 1
    • Turn the lock counter-clockwise to unlock access to the rotation brush; use a key or flathead screwdriver to fit the lock.
    • Remove the square brush cover to access the rotation brush.
    • Once unlocked, the small square brush holder will detach.
  4. Model-V2945Z Cordless Shark Floor and Carpet Sweeper-Rotating Brush Replacement: step 4, image 1 of 1
    • Remove the large band from the rotation brush.
    • Push the band to the side and lift up the right-side of the brush.
  5. Model-V2945Z Cordless Shark Floor and Carpet Sweeper-Rotating Brush Replacement: step 5, image 1 of 1
    • Detach left-side of the brush from the vacuum.
  6. Model-V2945Z Cordless Shark Floor and Carpet Sweeper-Rotating Brush Replacement: step 6, image 1 of 2 Model-V2945Z Cordless Shark Floor and Carpet Sweeper-Rotating Brush Replacement: step 6, image 2 of 2
    • Use scissors to cut away any debris entangled in the brush.
    • The brush is easily damaged by debris if not cleaned regularly; keeping the brush clean lengthens the life of the vacuum.
    • Clean the area surrounding the brush by scraping with a putty knife before inserting the replacement brush.
To reassemble the device, follow these instructions in reverse order.
3 other people completed this guide.
Robert Whelan
61 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 28
All Time: 3,490
