Midiman Oxygen 8 LCD Screen Replacement
  1. Midiman Oxygen 8 LCD Screen  Replacement, Midiman Oxygen 8 Backplate Disassembly: step 1, image 1 of 2 Midiman Oxygen 8 LCD Screen  Replacement, Midiman Oxygen 8 Backplate Disassembly: step 1, image 2 of 2
    • Remove the 8 mm M3 Phillips head self tapping machine screws.
    • Several of the screws are in narrow, deep sockets; make sure to use an appropriate screw driver to remove them so as not to damage the cover during removal.
    • Remove all 13 of the back plate screws.
  2. Midiman Oxygen 8 LCD Screen  Replacement: step 2, image 1 of 2 Midiman Oxygen 8 LCD Screen  Replacement: step 2, image 2 of 2
    • Remove the two highlighted 10 mm M3 galvanized machine screws using the J1 head fro the iFixit Tool Kit or a comparable tool.
  3. Midiman Oxygen 8 LCD Screen  Replacement: step 3, image 1 of 3 Midiman Oxygen 8 LCD Screen  Replacement: step 3, image 2 of 3 Midiman Oxygen 8 LCD Screen  Replacement: step 3, image 3 of 3
    • Removal of Ribbon Cables
    • Prior to removal, note, mark, or take photo’s of the position of all connectors. Specifically note the side that the red wire is on, as ribbon cables are polarized cables that must be re-installed correctly. Installing the cables backwards may cause damage to the device or significantly hinder the troubleshooting process.
    • To separate the back plate, remove all five cables that connect to the motherboard but do not originate from the back plate; the key assembly, LCD circuit, rotor tuning circuit, and the pitch and modulator circuits. None of these cables require tools to remove, simply apply firm upward pressure to remove them.
  4. Midiman Oxygen 8 LCD Screen  Replacement: step 4, image 1 of 2 Midiman Oxygen 8 LCD Screen  Replacement: step 4, image 2 of 2
    • Remove the key assembly from the key board.
    • What remains is the back plate and the top plate assemblies.
  5. Midiman Oxygen 8 LCD Screen  Replacement, LCD Screen: step 5, image 1 of 1
    • The LCD screen is attached to the same circuit as the Data Slide bar on the reverse of the front face plate.
    • Remove the four M1.5 x 3 screws
  6. Midiman Oxygen 8 LCD Screen  Replacement: step 6, image 1 of 1
    • There are 12 contacts that must be de-soldered in order to remove the LCD screen,
  7. Midiman Oxygen 8 LCD Screen  Replacement: step 7, image 1 of 1
    • Once the LCD screen has been de-soldered, it can be removed and replaced with a new screen.
Scott Miller
437 Reputation
4 Guides authored
USF Tampa, Team 1-6, Sullivan Fall 2016 Member of USF Tampa, Team 1-6, Sullivan Fall 2016
USFT-SULLIVAN-F16S1G6
4 Members
6 Guides authored
One Comment
It’s an LED display, not an LCD screen.
Peter D - Reply
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 241
