Microsoft Surface Laptop 7 (13.8-inch) Surface Connect Port Replacement
  1. Microsoft Surface Laptop 7 (13.8-inch) Surface Connect Port Replacement, Prepare your laptop for disassembly: step 1, image 1 of 3 Microsoft Surface Laptop 7 (13.8-inch) Surface Connect Port Replacement, Prepare your laptop for disassembly: step 1, image 2 of 3 Microsoft Surface Laptop 7 (13.8-inch) Surface Connect Port Replacement, Prepare your laptop for disassembly: step 1, image 3 of 3
    • Before starting this repair, allow your laptop's battery to drain below 25%. A charged battery may catch fire if damaged.
    • Unplug all cables and fully shut down your laptop.
  2. Microsoft Surface Laptop 7 (13.8-inch) Surface Connect Port Replacement, Flip your laptop over: step 2, image 1 of 3 Microsoft Surface Laptop 7 (13.8-inch) Surface Connect Port Replacement, Flip your laptop over: step 2, image 2 of 3 Microsoft Surface Laptop 7 (13.8-inch) Surface Connect Port Replacement, Flip your laptop over: step 2, image 3 of 3
    • Close your laptop and lay it down so the rubber feet are facing up.
  3. Microsoft Surface Laptop 7 (13.8-inch) Surface Connect Port Replacement, Remove the feet: step 3, image 1 of 3 Microsoft Surface Laptop 7 (13.8-inch) Surface Connect Port Replacement, Remove the feet: step 3, image 2 of 3 Microsoft Surface Laptop 7 (13.8-inch) Surface Connect Port Replacement, Remove the feet: step 3, image 3 of 3
    • Gently slide one arm of your angled tweezers into the recess near the upper right edge of one of the feet.
    • You can also use the point of a spudger. However, you're more likely to damage the foot, if you're reusing it.
    • Use your tweezers to pry up and remove the foot.
    • The feet may eject very quickly—be careful not to lose them.
    • Repeat the process to remove the remaining feet.
    • To install a foot, align the pegs on the bottom with their cutouts in the frame and press the foot into place.
  4. Microsoft Surface Laptop 7 (13.8-inch) Surface Connect Port Replacement, Remove the lower case screws: step 4, image 1 of 2 Microsoft Surface Laptop 7 (13.8-inch) Surface Connect Port Replacement, Remove the lower case screws: step 4, image 2 of 2
    Tool used on this step:
    FixMat
    $36.95
    Buy
    • While the Surface Laptop 7 uses Torx Plus screws, standard Torx bits work. Make sure to apply constant, downward force to prevent stripping.
    • Use a Torx Plus 5IP screwdriver to remove the four 4.5 mm‑long screws (with washers) securing the lower case.
  5. Microsoft Surface Laptop 7 (13.8-inch) Surface Connect Port Replacement, Detach the lower case: step 5, image 1 of 3 Microsoft Surface Laptop 7 (13.8-inch) Surface Connect Port Replacement, Detach the lower case: step 5, image 2 of 3 Microsoft Surface Laptop 7 (13.8-inch) Surface Connect Port Replacement, Detach the lower case: step 5, image 3 of 3
    • Insert the tip of an opening pick under the top edge of the lower case, about an inch (2.5 cm) to the left or right of the Microsoft logo.
    • Don't insert the pick near the outer edges or you'll damage the antenna bar.
  6. Microsoft Surface Laptop 7 (13.8-inch) Surface Connect Port Replacement: step 6, image 1 of 3 Microsoft Surface Laptop 7 (13.8-inch) Surface Connect Port Replacement: step 6, image 2 of 3 Microsoft Surface Laptop 7 (13.8-inch) Surface Connect Port Replacement: step 6, image 3 of 3
    • Twist the pick to lift the lower case enough that you can grip it with your hand.
  7. Microsoft Surface Laptop 7 (13.8-inch) Surface Connect Port Replacement, Remove the lower case: step 7, image 1 of 3 Microsoft Surface Laptop 7 (13.8-inch) Surface Connect Port Replacement, Remove the lower case: step 7, image 2 of 3 Microsoft Surface Laptop 7 (13.8-inch) Surface Connect Port Replacement, Remove the lower case: step 7, image 3 of 3
    • Lift the lower case and remove it.
  8. Microsoft Surface Laptop 7 (13.8-inch) Surface Connect Port Replacement, Disconnect the battery: step 8, image 1 of 3 Microsoft Surface Laptop 7 (13.8-inch) Surface Connect Port Replacement, Disconnect the battery: step 8, image 2 of 3 Microsoft Surface Laptop 7 (13.8-inch) Surface Connect Port Replacement, Disconnect the battery: step 8, image 3 of 3
    • Use a Torx Plus 3IP screwdriver to remove the two 2.3 mm‑long screws securing the battery connector cover.
  9. Microsoft Surface Laptop 7 (13.8-inch) Surface Connect Port Replacement: step 9, image 1 of 2 Microsoft Surface Laptop 7 (13.8-inch) Surface Connect Port Replacement: step 9, image 2 of 2
    • Use tweezers or your fingers to remove the battery connector cover.
  10. Microsoft Surface Laptop 7 (13.8-inch) Surface Connect Port Replacement: step 10, image 1 of 2 Microsoft Surface Laptop 7 (13.8-inch) Surface Connect Port Replacement: step 10, image 2 of 2
    • Insert the flat end of a spudger under the top edge of the battery press connector and pry up to disconnect it.
    • To reconnect a press connector, align it over the socket and gently press down on one side until it clicks into place, then press down on the other side. It may take a few tries to align the connector—don't try to force it into place.
  11. Microsoft Surface Laptop 7 (13.8-inch) Surface Connect Port Replacement, Disconnect the Surface Connect port: step 11, image 1 of 3 Microsoft Surface Laptop 7 (13.8-inch) Surface Connect Port Replacement, Disconnect the Surface Connect port: step 11, image 2 of 3 Microsoft Surface Laptop 7 (13.8-inch) Surface Connect Port Replacement, Disconnect the Surface Connect port: step 11, image 3 of 3
    • Use the flat end of a spudger to flip up the metal buckle on the Surface Connect port connector.
  12. Microsoft Surface Laptop 7 (13.8-inch) Surface Connect Port Replacement: step 12, image 1 of 2 Microsoft Surface Laptop 7 (13.8-inch) Surface Connect Port Replacement: step 12, image 2 of 2
    • Use tweezers or your fingers to grip the Surface Connect port cable and pull it straight out of its socket.
    • During reassembly:
    • Reconnect the Surface Connect port cable.
    • Remove any adhesive liners and press the cable into place to secure it with the adhesive.
  13. Microsoft Surface Laptop 7 (13.8-inch) Surface Connect Port Replacement, Remove the Surface Connect port screws: step 13, image 1 of 2 Microsoft Surface Laptop 7 (13.8-inch) Surface Connect Port Replacement, Remove the Surface Connect port screws: step 13, image 2 of 2
    • Use a Torx Plus 3IP screwdriver to remove the two 3 mm‑long screws securing the Surface Connect port to the top left corner of the frame.
  14. Microsoft Surface Laptop 7 (13.8-inch) Surface Connect Port Replacement, Separate the cable adhesive: step 14, image 1 of 1
    • A strong strip of adhesive secures the Surface Connect port cable to the top of the fan. Heating the cable softens the adhesive, making it easier to separate.
    • Heat an iOpener and lay it on the Surface Connect port cable for two minutes to soften the adhesive.
    • Alternatively, you can use a hair dryer or heat gun. But be careful, as extreme heat can damage the battery.
  15. Microsoft Surface Laptop 7 (13.8-inch) Surface Connect Port Replacement: step 15, image 1 of 2 Microsoft Surface Laptop 7 (13.8-inch) Surface Connect Port Replacement: step 15, image 2 of 2
    Tesa 61395 Tape
    $2.99
    Buy
    • Grip the Surface Connect cable close to the motherboard connector and peel the cable from the fan.
    • Don't secure the trackpad cable with adhesive yet—wait until you've reconnected it. Otherwise, the cable may not reach its socket if positioned incorrectly.
    • If the tape is still sticky, you don't need to replace it.
    • If the adhesive is no longer sticky, or if you're replacing the fan and it doesn't have adhesive, apply a new strip of thin, double-sided tape to the top edge of the fan.
  16. Microsoft Surface Laptop 7 (13.8-inch) Surface Connect Port Replacement, Remove the Surface Connect port: step 16, image 1 of 3 Microsoft Surface Laptop 7 (13.8-inch) Surface Connect Port Replacement, Remove the Surface Connect port: step 16, image 2 of 3 Microsoft Surface Laptop 7 (13.8-inch) Surface Connect Port Replacement, Remove the Surface Connect port: step 16, image 3 of 3
    • Lift and remove the Surface Connect port.
    • Put the Surface Connect port into place so its cutouts go over their posts on the motherboard. Make sure the port is fully in its cutout—the outer edge should be flush with the frame.
    • Install the two screws that secure the port.
Spencer Day
162,969 Reputation
1,043 Guides authored
iFixit Member of iFixit
Staff
124 Members
24,166 Guides authored
2 Guide Comments
感谢作者,我的 Laptop+7 充电口坏了,还在保修期。售后要5000+RMB。自己买了配件才花了75RMB。本来是要自己研究下怎么修复呢。看到了作者的教程。非常感激。等修复完成后我再上来标记下
zhang tao - Reply Share
已完成更换,开背壳时要注意,不要撬到屏幕那里去了。是最外面那层。
Past 24 Hours: 5
Past 7 Days: 13
Past 30 Days: 58
All Time: 630
