Introduction
You will need to take apart the Screen Frame, the LCD screen, and the sensor ribbon as a prerequisite to get to the motherboard. You might want to use a magnetic mat to make sure you don't lose the small screws.
Warning: The following guide is likely to ruin the water resistance of the device.
Heat the iOpener. Instructions on how to do this can be found here: iOpener Instructions
Firmly press the frame of the band against the iOpener, and hold it in place for about 90 seconds.
Using a spudger, lightly press upwards against one corner of the frame, then the other along the corner of the short edge.
Alternating between the same two corners, continue pressing until there's about a 1-2 mm gap between that end of the frame and the body.
Insert the spudger into the gap under the frame, and lightly slide it about 3/4 of the way down one of the long edges, then repeat with the other.
If the frame doesn't simply pop off, try sliding the spudger the rest of the way down the long edges, and lightly lift the frame with your fingers.
Lightly pry up the black connector from the motherboard using a spudger.
Pull the entire LCD screen gently upward to detach the yellow ribbon cable.
Using the spudger and your fingers, gently lift the motherboard from the band socket.
You should feel a "pop."
Gently flip the motherboard so that you are viewing the motherboard from underneath.
Using the tweezers, gently detach the golden connector from the back of the motherboard.
