Introduction
There are two batteries in the band, located in the side panels. One battery compartment contains a vibrator, but the replacement steps are essentially the same.
Warning: The following guide is likely to ruin the water resistance of the device.
To reassemble your device, follow these instructions in reverse order. Replace the vibrator in its original compartment.
4 other people completed this guide.
5 Comments
From what I can tell it's something like this:
http://www.alibaba.com/product-detail/Ho...
which is a 3.7v flat lithium ion polymer 72mAh battery. Min order is 1030 though! You can find similar on AliExpress if you search for that description. The dimensions are listed as 4*14.8*21.5mm so it'll need to be within that, or maybe the OP can confirm the battery size?
Simon -
Will this be dangerous?
Anyway to upgrade to a higher capacity battery to get better life out of it? With GPS on, it dies in 2 hours and I go on 8 hr hikes.
No tak wszystko fajnie ale gdzie te akumulatory zakupić ?
