Mia Toro Luggage Wheel Replacement
  1. Mia Toro Luggage Wheel Replacement, Mia Toro Luggage Wheel: step 1, image 1 of 3 Mia Toro Luggage Wheel Replacement, Mia Toro Luggage Wheel: step 1, image 2 of 3 Mia Toro Luggage Wheel Replacement, Mia Toro Luggage Wheel: step 1, image 3 of 3
    • Unzip the inner lining on the side of the suitcase where the broken wheel is located.
    • Lift the lining to the side and you will be able to see the screws holding the wheel in place.
  2. Mia Toro Luggage Wheel Replacement: step 2, image 1 of 1
    • Use a Phillips #2 screwdriver to remove the four screws securing the damaged wheel.
  3. Mia Toro Luggage Wheel Replacement: step 3, image 1 of 1
    • Pull the damaged wheel assembly straight out from the suitcase to remove it.
    • The wheel should come off very easily once the screws are removed.
  4. Mia Toro Luggage Wheel Replacement: step 4, image 1 of 2 Mia Toro Luggage Wheel Replacement: step 4, image 2 of 2
    • Align the new wheel with the screw holes in the wheel housing.
    • Make sure it sits flush against the luggage.
  5. Mia Toro Luggage Wheel Replacement: step 5, image 1 of 1
    • Insert the screws into the wheel assembly from the inside of the suitcase and use the Phillips #2 screwdriver to tighten them evenly.
    • Ensure the wheel is firmly attached but avoid overtightening, which could lead to stripping the screw holes.
  6. Mia Toro Luggage Wheel Replacement: step 6, image 1 of 1
    • Spin the wheel and roll the luggage to ensure smooth movement.
    • If the wheel wobbles or feels loose, check and tighten the screws as needed.
    • Zip the inner lining back into place and your luggage is ready to use!
Beatriz Amaral Soares
133 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 33
Past 30 Days: 115
All Time: 1,315
