This translation may not reflect the most recent updates from the source guide. Help update the translation or view the source guide.
Medion Akoya P6640 (MD 99220) Switching HDD with SSD
  1. Medion Akoya P6640 (MD 99220) Switching HDD with SSD, Turn off the laptop: step 1, image 1 of 2 Medion Akoya P6640 (MD 99220) Switching HDD with SSD, Turn off the laptop: step 1, image 2 of 2
    • First, the laptop must be disconnected from the charger and powered off completely. To do this, shut down Windows using ctrl+alt+del.
    • Ground yourself by touching a suitable object in order to get rid of any electrostatic charge.
    • Close the laptop, and flip it over so that the back cover is facing upwards.
  2. Medion Akoya P6640 (MD 99220) Switching HDD with SSD, Removal of exterior screws: step 2, image 1 of 2 Medion Akoya P6640 (MD 99220) Switching HDD with SSD, Removal of exterior screws: step 2, image 2 of 2
    • The 9 visible screws, highlighted in red and orange, must be removed in order to remove the back cover.
    • Additionally, the screws highlighed in orange are protected by rubber caps. Use a needle to remove the caps (see image 2).
  3. Medion Akoya P6640 (MD 99220) Switching HDD with SSD, Unlatching the drive: step 3, image 1 of 1
    • In order to remove the drive, the drive bay must be unlocked. To do this, move the latch in the direction of the arrow.
  4. Medion Akoya P6640 (MD 99220) Switching HDD with SSD, Eject the drive: step 4, image 1 of 1
    • After the drive bay is unlatched, the eject button must be pushed.
    • To do so, place your finger in the recess and push in the direction of the arrow.
  5. Medion Akoya P6640 (MD 99220) Switching HDD with SSD, Drive Removal: step 5, image 1 of 1
    • After pressing the Eject button, the drive pops out, and can easily be removed.
    • Keep the drive somewhere safe.
  6. Medion Akoya P6640 (MD 99220) Switching HDD with SSD, Unlatch the battery: step 6, image 1 of 1
    • To remove the battery, the latch must be unlocked.
    • Push the latch in the direction of the arrow.
  7. Medion Akoya P6640 (MD 99220) Switching HDD with SSD, Unlatching the battery (cont.): step 7, image 1 of 1
    • The second latch, highlighted, must be pushed in the direction shown.
    • The latch is spring-loaded. Hold it in place with your finger.
  8. Medion Akoya P6640 (MD 99220) Switching HDD with SSD, Battery Removal: step 8, image 1 of 1
    • While holding the latch with your hand, use your other hand to reach into the recess and lift the battery outwards and slightly upwards.
    • Store the battery somewhere safe.
  9. Medion Akoya P6640 (MD 99220) Switching HDD with SSD, Screw Removal: step 9, image 1 of 1
    • In the battery compartment, there are three small screws, shown here.
    • All screws must be removed in order to remove the back cover.
  10. Medion Akoya P6640 (MD 99220) Switching HDD with SSD, Removing the housing: step 10, image 1 of 1
    • First, unclip the four visible clips in the drive bay.
    • Use a screwdriver or other tool to slightly push the clips in the direction shown.
    • Be careful, the clips are fragile.
  11. Medion Akoya P6640 (MD 99220) Switching HDD with SSD, Removing the housing (cont.): step 11, image 1 of 1
    • Similar clips are also in the battery compartment.
    • Unclip these carefully, following the same process as before.
    • This will create an opening at the top left of the housing.
  12. Medion Akoya P6640 (MD 99220) Switching HDD with SSD, Removing the housing (cont.): step 12, image 1 of 1
    • With a plastic spatula or flat plastic tool, go along the gap around the housing.
    • The tabs around the rest of the housing can be easily opened by moving along the gap and lightly pressing inwards.
    • Be careful, and don't use much force. The latches will make a small noise when they are removed, ignore this.
  13. Medion Akoya P6640 (MD 99220) Switching HDD with SSD, Overview: step 13, image 1 of 1
    • CPU with cooler
    • RAM
    • BIOS button cell
    • Speaker units
    • Hard disk
  14. Medion Akoya P6640 (MD 99220) Switching HDD with SSD, Speaker removal: step 14, image 1 of 1
    • To get to the hard disk, we have to remove the left speaker.
    • To do this, pull the cable connection upwards. The connector has two wings for this (push them together, and then pull the cable).
  15. Medion Akoya P6640 (MD 99220) Switching HDD with SSD, Speaker removal (cont.): step 15, image 1 of 1
    • To remove the speaker, this screw must be removed.
    • Then, remove the loudspeaker upwards from the plastic centering pieces.
  16. Medion Akoya P6640 (MD 99220) Switching HDD with SSD, USB Daughterboard Removal: step 16, image 1 of 1
    • In order to remove the hard drive, this screw must be removed.
    • To make it easier to remove the hard drive, you can remove the entire daughterboard.
    • To do this, carefully bend back the hooks marked blue, attention unstable and remove the unit upwards and fold it backwards away from the cable.
  17. Medion Akoya P6640 (MD 99220) Switching HDD with SSD, Hard drive removal: step 17, image 1 of 1
    • The hard drive can now be removed.
    • To do this, move the hard drive towards the left, out of the SATA sockets, to remove it.
  18. Medion Akoya P6640 (MD 99220) Switching HDD with SSD, Transplanting the frame: step 18, image 1 of 2 Medion Akoya P6640 (MD 99220) Switching HDD with SSD, Transplanting the frame: step 18, image 2 of 2
    • Remove the screws securing the frame
    • Remove the frame from the hard drive.
    • Attach the frame to the new SSD. Make sure you install it the right way around.
  19. Medion Akoya P6640 (MD 99220) Switching HDD with SSD: step 19, image 1 of 1
    • Push the SSD back into the socket
    • Re-attach the USB Daughterboard
    • Put the speaker back, and screw it in.
  20. Medion Akoya P6640 (MD 99220) Switching HDD with SSD, BIOS battery removal: step 20, image 1 of 1
    • To do this, place the screwdriver in the front of the groove.
    • Press the button cell in the direction of the arrow, and then lift it upwards.
    • You can now place a new battery in. Push it in until it clicks.
    • Reassemble the housing in reverse order
    • Clip everything back in
    • Return all the screws
    • Put the battery and drive back
    • You're done!
Work through the steps in reverse order to reassemble your device.
All work is always done at your own risk. I assume no liability for completeness or correctness of the instructions.
Any manufacturer warranties will be voided by the repair.
If you can not do fine motor work, then I strongly advise against this replacement.
Special thanks to these translators:
de en
97%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Benni B
373 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 6
Past 7 Days: 35
Past 30 Days: 118
All Time: 1,603
