Manfrotto Ranker Stand APoS mondified Leg & strut Replacement
  1. Manfrotto Ranker Stand APoS mondified Leg & strut Replacement, Rivet Removal: step 1, image 1 of 3 Manfrotto Ranker Stand APoS mondified Leg & strut Replacement, Rivet Removal: step 1, image 2 of 3 Manfrotto Ranker Stand APoS mondified Leg & strut Replacement, Rivet Removal: step 1, image 3 of 3
    • Using a drill, drill out enough of the rivet head so that the rivet may be removed.
    • If the rivet spins, use pliers or a flat head screw driver to hold the rivet in place
  2. Manfrotto Ranker Stand APoS mondified Leg & strut Replacement, Rivet Removal: step 2, image 1 of 2 Manfrotto Ranker Stand APoS mondified Leg & strut Replacement, Rivet Removal: step 2, image 2 of 2
    • Once you have dissembled the legs and spreader struts
  3. Manfrotto Ranker Stand APoS mondified Leg & strut Replacement, Cut down the spreader strut: step 3, image 1 of 3 Manfrotto Ranker Stand APoS mondified Leg & strut Replacement, Cut down the spreader strut: step 3, image 2 of 3 Manfrotto Ranker Stand APoS mondified Leg & strut Replacement, Cut down the spreader strut: step 3, image 3 of 3
    • Cut spreader strut to 200mm
    • use a punch to mark the centre of the spreader strut
    • drill 6mm hole through spreader strut
    • round end off to replicate the original end, with a file
  4. Manfrotto Ranker Stand APoS mondified Leg & strut Replacement, Cut legs down: step 4, image 1 of 1
    • Legs should be cut down to 400 mm
Finish Line
nickjvturner
101 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 127
