Makita DX02 Dust Extraction Unit for BHR243 Motor and Fan Wheel Repair
View statistics:
Past 24 Hours:
8
Past 7 Days:
29
Past 30 Days:
84
All Time:
753
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Community-Contributed Guide
Introduction
Go to step 1 ↓
In this guide, I'll show you how to replace the motor including the fan wheel.
This is necessary if:
- the motor is defective (no longer spins)
- the fan wheel is defective
The fan wheel has the number printed on it: 2401323
The original spare part number for the fan wheel and motor is: 141163-4
    1. Makita DX02 Dust Extraction Unit for BHR243 Motor and Fan Wheel Repair, Preparation: step 1, image 1 of 1
      • Detaching the Unit from the Cordless Drill
      • Remove the Dust Box
      • if necessary, vacuum the dust out of the unit as much as possible at this point (optional)
      Ask FixBot
    2. Makita DX02 Dust Extraction Unit for BHR243 Motor and Fan Wheel Repair, Removing the Housing Screws: step 2, image 1 of 1
      • Remove the 8 housing screws with the Phillips screwdriver.
      Ask FixBot
    3. Makita DX02 Dust Extraction Unit for BHR243 Motor and Fan Wheel Repair, Removing the Housing Cover: step 3, image 1 of 2 Makita DX02 Dust Extraction Unit for BHR243 Motor and Fan Wheel Repair, Removing the Housing Cover: step 3, image 2 of 2
      • Remove the Housing Cover
      Ask FixBot
    1. Makita DX02 Dust Extraction Unit for BHR243 Motor and Fan Wheel Repair, Removing the Motor and Fan Wheel Mount: step 4, image 1 of 3 Makita DX02 Dust Extraction Unit for BHR243 Motor and Fan Wheel Repair, Removing the Motor and Fan Wheel Mount: step 4, image 2 of 3 Makita DX02 Dust Extraction Unit for BHR243 Motor and Fan Wheel Repair, Removing the Motor and Fan Wheel Mount: step 4, image 3 of 3
      • Remove the motor and fan wheel bracket by lifting it upwards.
      • if necessary, remove any remaining pieces of the fan wheel
      • if necessary, this may need to be done together with the motor (following step)
      Ask FixBot
    2. Makita DX02 Dust Extraction Unit for BHR243 Motor and Fan Wheel Repair, Removing the motor: step 5, image 1 of 2 Makita DX02 Dust Extraction Unit for BHR243 Motor and Fan Wheel Repair, Removing the motor: step 5, image 2 of 2
      • Pull the clamps off towards the back using the pliers.
      • Take the motor out by lifting it upwards.
      • When installing the new motor, pay attention to the polarity (plus/minus, red/black)! This is usually marked on the motor with a red dot.
      Ask FixBot
To reassemble your device, follow the steps in reverse order.
Special thanks to these translators:
de en
100%
hainzy is helping us fix the world! Want to contribute?
Start translating ›
hainzy
11,173 Reputation
48 Guides authored
0 Guide Comments
Past 24 Hours: 8
Past 7 Days: 29
Past 30 Days: 84
All Time: 753
