Sort the parts and take the small metal spring
Use the ifixit reverse tweezers
Push the metal spring through the opening into the cover
Connect the lid with the spring to the cover
Carefully slide the electronics block together with the cover and lid, but make sure it is on the correct side (see the recess at the bottom for the charger). When everything is in place, press lightly until it clicks into place.
If the control light in the lid and on the bottom side is on, you got it !!!!
Work through the steps in reverse order to reassemble your device.
Special thanks to these translators:
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
