Fix Your Stuff
Right to Repair
Parts & Tools
Introduction
(Disclaimer: Remove batteries before proceeding)
Parts
No parts specified.
  1. Flip the guitar over so it is back side up. The battery compartment should be facing up.
    • Flip the guitar over so it is back side up. The battery compartment should be facing up.
    • Use a size J1 head screwdriver to remove the ten 5 mm short screws.
    • Use a J1 screwdriver to remove the four 5 mm long screws on the back of the device.
  2. Manta Driver Kit
    112 bits for every fix.
    Upgrade Your Toolbox
    Manta Driver Kit
  3. Turn the device over so the front of the guitar is facing you.
    • Turn the device over so the front of the guitar is facing you.
    • Using a size J1 philips head screwdriver, remove the eleven 5 mm silver screws (circled in red) around the white panel.
  4. Gently lift the white panel and twist 90 degrees clockwise.
    • Gently lift the white panel and twist 90 degrees clockwise.
    • Using a size J1 head screwdriver, remove the two 5 mm black screws from underneath the white panel. You should now be able to pull the guitar apart.
Catherine Lintner
533 Reputation
4 Guides authored
USF Tampa, Team 1-1, Cagle Fall 2016 Member of USF Tampa, Team 1-1, Cagle Fall 2016
USFT-CAGLE-F16S1G1
4 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 70
