Introduction
Replacing a defective fan is pretty easy and will keep your laptop running cool.
Use your fingers to push both battery release tabs away from the battery and lift the battery out of the computer.
Remove the four identical Phillips 3.4 mm screws from the memory door. These screws have 4 mm diameter heads rather than the 3 mm heads on the body screws.
Lift the memory door up enough to get a grip on it, and slide it toward you, pulling it away from the casing.
Remove the three Phillips screws in the battery compartment near the latch. Apple was nice enough to tilt these screws at a slight angle to make them easier to remove. On the A1261 these screws have 4 mm diameter heads rather than the 3 mm heads on the body screws.
Remove the following six screws:
Two 14.5 mm T6 Torx screws on either side of the RAM slot.
Four 3.4 mm Phillips screws along the hinge.
Rotate the computer 90 degrees and remove the two Phillips screws from the rear of the computer.
Rotate the computer 90 degrees again and remove the four Phillips screws from the side of the computer.
Lift up the back of the case and work your fingers along the sides, freeing the case as you go. Once you have freed the sides, you may need to rock the case up and down to free the front of the upper case.
Disconnect the trackpad and keyboard ribbon cable from the logic board.
Remove the upper case.
Remove the single black T6 Torx screw from the top right corner of the AirPort Extreme card.
Remove the two silver T6 Torx screws from the top left and bottom right corners of the left speaker assembly.
Lift up the left speaker assembly with one hand and deroute the inverter cable from the top right corner of the speaker assembly.
Disconnect the pink and black left speaker assembly cable from the left I/O board. Be sure to pull only on the white connector and not on the speaker wires.
Disconnect the microphone cable connector from the left I/O board.
Remove the left speaker/microphone assembly from the lower case.
Peel up the iSight and inverter cables which are attached with a mild adhesive above the left fan.
