Introduction
Use this guide to safely remove the glued-in battery from your 16” MacBook Pro with the help of an iFixit kit with adhesive remover. The adhesive remover is designed to weaken the glue securing the battery, allowing you to remove it with ease.
iFixit adhesive remover is flammable. Follow this procedure in a well-ventilated area. Do not smoke or work near an open flame.
To minimize risk of damage, turn on your MacBook and allow the battery to fully discharge before starting this procedure. A charged lithium-ion battery can create a dangerous and uncontrollable fire if accidentally punctured. If your battery looks puffy or swollen, take extra precautions.
Note: The solvent used to dissolve the battery adhesive can damage certain plastics. Follow all instructions and take care where you apply the adhesive remover.
Power on your Mac and launch Terminal.
Copy and paste the following command (or type it exactly) into Terminal:
sudo nvram AutoBoot=%00
Press [return]. If prompted, enter your administrator password and press [return] again. Note: Your return key may also be labeled ⏎ or "enter."
sudo nvram AutoBoot=%03
Tool used on this step:Magnetic Project Mat$19.95
Use a P5 Pentalobe driver to remove six screws securing the lower case, of the following lengths:
Four 3.7 mm screws
Two 7.3 mm screws
Press a suction handle into place near the front edge of the lower case, between the screw holes.
Pull up on the suction handle just enough to open a small gap under the lower case.
Slide the corner of an opening pick into the gap you just created underneath the lower case.
Slide the opening pick around the nearest corner and then halfway up the side of the MacBook Pro.
I recommend being careful while sliding as you can scratch the speaker. The actual clip is about halfway up the side, whereas the speaker is closer to the front (further from the hinge). So stay very shallow with just the tip of the pick until you get halfway up the side.
Repeat the previous step on the other side, using an opening pick to to release the second clip.
Same advice that I gave for the other side — be careful not to scratch the speaker which is close to the bottom. Keep the pick shallow until you get halfway up the side.
Pull firmly to slide the lower case towards the front edge of the MacBook (away from the hinge area) to separate the last of the clips securing the lower case.
Pull first at one corner, then the other.
This was made a lot easier by using a lever in the hinge area in combination with pulling. The amount of force required was more than the grip I could get on the metal allowed for my macbook.
Thank you for this comment! 🙏
For me it was the same way, wasn't able to get enough grip to pull sufficiently - but gently levering near the hinge with a spudger to "push" the bottom panel away worked well!There is no pulling required. Use an opening pick or a spudger at the hinge area to gently and easily nudge the bottom panel off the clips. It should be effortless.
If you do pull on the bottom case be careful of where you place the hand supporting the Mac, otherwise you'll make a blood sacrifice to the Mac gods! I placed my other hand too close to the feet on the bottom case and while removing it, the sharp edge of the bottom case sliced into my thumb.
Remove the lower case.
Set it in place and align the sliding clips near the display hinge. Press down and slide the cover toward the hinge. It should stop sliding as the clips engage.
When the sliding clips are fully engaged and the lower case looks correctly aligned, press down firmly on the lower case to engage the four hidden clips underneath. You should feel and hear them snap into place.
Peel up and remove the insulating sticker covering the battery board, on the edge of the logic board nearest the battery.
If the cover doesn't peel up easily, apply mild heat with an iOpener, hair dryer, or heat gun to soften the adhesive underneath, and try again.
Use a spudger to gently pry up the locking flap on the ZIF connector for the battery board data cable.
Disconnect the battery board data cable by sliding it out from its socket on the logic board.
Peel back any tape covering the battery board data cable connector.
Pry up and disconnect the locking flap on the connector at the opposite end of the battery board data cable.
I’ve seen versions of this battery board that the cable goes around and to the back of the board, so this step is not always necesary.
Slide the battery board data cable out of its socket on the battery board, and remove it completely.
Putting a mark on the cable will be helpful when reinstalling so you don't put it backwards or upside down.
This isn't necessary for many repairs, such as the Screen Replacement. I just lift the cable out of the way enough to do the next few steps and leave it attached.
Use a T5 Torx driver to remove the 6.7 mm pancake screw securing the battery power connector.
Use a T3 Torx driver to remove the two 1.8 mm screws securing the cover bracket for the keyboard and trackpad cable connectors.
Remove the bracket.
Use a spudger to disconnect the trackpad cable by prying its connector straight up from the logic board.
Use a T5 Torx driver to remove the 13 screws securing the trackpad assembly:
Nine 5.8 mm screws
Four 4.9 mm screws
Swing the display open slightly, but keep the MacBook upside-down. The trackpad assembly should separate and lay flat on the display.
Carefully feed the trackpad's ribbon cable through its slot in the chassis.
As you remove the trackpad assembly, be very careful not to lose the nine small metal washers resting on the screw posts. (They will fly off and get lost with very little provocation.)
Remove the trackpad assembly.
Use a T3 Torx driver to remove the two 3.5 mm screws securing the cover on the display board flex cable.
Remove the display board flex cover.
If you're familiar with repairing, you do not need to do a complete tear down, you can skip from here to step 63 and just loosen (or you can remove) the Three 3.3 mm T3 Torx screws (red) and the T5 screw (Yellow)below the left fan and slightly lift the logic board enough to slide out the battery board cable from under the logic board.
Use a T3 Torx driver to remove the four 2.0 mm screws from the hinge covers (two screws on each side).
Bonjour @amaury29177 Merci de remarque. Vous avez l'œil ! J'ai corrigé l'erreur. iFixit étant un wiki, je vous invite à faire la correction de votre côté s'il vous arrive de trouver une autre erreur :) Excellente journée et merci encore !
Use a T3 Torx driver to remove the two 2.4 mm screws securing the cover bracket for the Touch ID and headphone jack cable connectors.
Remove the bracket.
Using a T3 Torx driver, remove the two 1.5 mm screws securing the cover bracket for the Touch Bar digitizer and lid angle sensor connectors.
Using your tweezers, slide the bracket toward the side edge of the MacBook Pro until it clears the slotted retaining tab on the logic board.
Remove the bracket.
Use a T3 Torx driver to remove the two 1.9 mm screws securing the bracket for the Touch Bar display cable connector.
Remove the bracket.
Using a T3 Torx Driver:
Remove the two 1.3 mm screws securing the Thunderbolt flex cable cover on the left.
Remove two more 1.3 mm screws from the Thunderbolt cable cover on the right.
Peel back the tape covering the keyboard cable connector.
Use a spudger to gently pry straight up on the long locking flap on the ZIF connector for the keyboard cable.
Peel back any tape covering the left speaker cable connector.
Peel back any tape covering the right speaker cable connector.
Peel back any tape covering the first keyboard backlight cable connector.
Open the locking flap on the keyboard backlight's ZIF connector by prying it straight up from the logic board.
Disconnect the keyboard backlight by pulling its cable away from the logic board until it releases from its socket.
If possible, pull on the tape attached to the cable, rather than the cable itself, to reduce the risk of damage.
Move the cable away from its connector so it can more easily clear the logic board during removal.
Open the locking flap on the right fan's ZIF connector by prying it straight up from the logic board.
Disconnect the right fan by pulling its cable away from the logic board until it releases from its socket.
Open the locking flap on the left fan's ZIF connector by prying it straight up from the logic board.
Disconnect the left fan by pulling its cable away from the logic board until it releases from its socket.
Peel back any tape covering the other keyboard backlight connector.
Peel back any tape covering the microphone array connector.
Open the locking flap on the microphone array's ZIF connector by prying it straight up from the logic board.
Disconnect the microphone array by pulling its cable away from the logic board until it releases from its socket.
Use a T5 Torx driver to remove the single 2.9 mm screw securing the antenna cable bundle.
Disconnect all three antenna cables by prying each one straight up from its socket.
Slide your tweezers or the flat end of your spudger underneath each cable until it's near the socket, and then gently twist or pry up to disconnect it.
One tip to make logic board removal and replacement easier, is to carefully tape all the flexes back out of the way. This makes it a lot easier, trust me. Paul Daniels of FlexBV fame taught me this https://pldaniels.com/flexbv/ See photo of taped back flexes here https://i.imgur.com/eriX0KV.jpg
Remove all eleven screws securing the logic board assembly:
Two 3.6 mm T5 Torx screws
Four 2.9 mm T5 Torx screws
One 4.0 mm T8 Torx screw
One 4.0 mm T8 Torx screw (large head)
Peel up (but don't remove) the rubber vibration damping strip from the adhesive holding it to the fan.
If needed, apply mild heat with an iOpener, hair dryer, or heat gun to soften the adhesive and make the dampers easier to separate.
Repeat for the other adhesive strip on the opposite fan.
Feed the antenna cable bundle through the gap between the logic board and heat sink, and make sure it lines up correctly as you lower the board into place.
Verify that no cables get trapped under the board as you install it. Check each of the fifteen marked locations carefully.
So easy to refit the logic board with all the flexes taped back out of the way. The only way to go IMO https://i.imgur.com/1fiRGhe.jpg
To protect your display, place a sheet of aluminum foil between the display and keyboard and leave it there while you work.
Additionally, use painter's tape to seal off the area under the trackpad as best you can. Optionally, you may also layer an absorbent towel directly underneath the trackpad area to soak up any excess adhesive remover.
Now that your MacBook Pro is fully prepped, it's time to prep yourself.
Wear eye protection when handling and applying the adhesive remover. (Eye protection is included in your kit.)
Do not wear contact lenses without eye protection.
Protective gloves are also included in your kit. If you are concerned about possible skin irritation, put your gloves on now.
Tool used on this step:Plastic Cards$2.99
After a couple minutes, insert one corner of a plastic card underneath the battery, starting from the lower edge of the bottom, right-most cell.
Wiggle the card from side to side and slide it all the way underneath both battery cells.
Lift the cells to fully separate the adhesive, but don't try to remove them from your MacBook yet.
Leave the plastic card temporarily underneath the cells to prevent the adhesive from re-bonding as you proceed to the next step.
Lift and remove the battery.
Peel off any large strips of adhesive using tweezers or gloved fingers.
Scrape away any remaining chunks of adhesive with a plastic tool, and clean the underlying areas with adhesive remover or isopropyl alcohol. Wipe in one direction (not back and forth) until the chassis is clean and ready for your new battery.
This can take quite a bit of work, so be patient.
Tool used on this step:Tesa 61395 Tape$10.99
If your battery came with adhesive pre-installed on the bottom, flip it over and carefully peel away the liner to expose the adhesive. If your battery did not come with adhesive, apply a thin double-sided adhesive tape such as Tesa 61395 to keep your battery in place.
Carefully position the battery and set it into place.
Press and hold each cell firmly for 5-10 seconds to secure it to the lower case.
Repair didn’t go as planned? Ask our Answers community for troubleshooting help.
45 other people completed this guide.
32 Comments
Amazing. This is truly thorough, and as soon as this battery starts to fail, will come back here. Nice work documenting a whole assembly line.
If I want to replace my fans, it looks like I can follow this guide to step 66 and then just figure it out from there? Is there a guide somewhere on this? Thanks!
You can do as you wrote for replacing only the fan. Ther’s nothing more to know about it.
I see that the MacBook Pro 13 logic board remains in place in iFixit battery replacement guide. Is there any reason why in the MacBook Pro 16 the logic board cannot remain in place while removing and reinstalling the battery?
Yes, there are two battery cables running under the logic board, clearly visible at step 68. No way to put the battery back with the logic board in place.
I recently did the 15” 2017 Macbook Pro battery replacement and that seemed more difficult than this one due to the speaker connectors. In my opinion, this 16” replacement can be marked as Moderate.
Because the battery connector is underneath the logic board here.
Peter H -
Great guide! Wow! Definitely not for the faint of heart! Thanks Carsten!
This is definitely a difficulty repair. I caused some damage to the speaker, likely while trying to get the battery out. (Luckily, that will be a very simple repair)
I definitely recommend double checking that you have all right screwdrivers, scrapers/spudgers, adhesive dissolvers, screw locker and a tray with lots of compartments to keep everything organized. I have done multiple complex repairs of mac laptops in the past including screen replacements, logic board replaceements and other battery replacements and this was the most difficult. I am very glad future generations included pull tabs for the adhesive.
Thanks for the guide!
FWIW I skipped about half the steps, and used spudgers to angle the motherboard up, in order to remove the battery. I'll list the steps I followed below:
1-21
27-29
35-36
41-49
53-54
61
63
68
I use 99% isopropyl alcohol, and an ifixit plastic card to cut through the battery adhesive. TBH that was the most time-consuming part, because I like to let the alcohol melt the adhesive a bit before cutting, in order to minimize the amount of pressure I have to apply.
The reason I skipped a lot of steps is to minimize risk, and also to save time. Thankfully the battery ribbons were easy to slide underneath the board, once the board was angled up a bit.
What a nightmare... There's no way this wasn't done in purpose.
2 years in and the battery's already dead. That's insane.
This took longer than expected due to the logic board removal, but wasn’t too difficult and everything went to plan.
Note that you need to be REALLY careful with the ZIF connector latches like on the battery board and logic board, they are very fragile and I had to re-attach the latch for one of them.
OMG!! I did not know that the process to change out the battery on the 2019 MBP was so intense. My old 2009 MBP was "cake walk" compared to this. Thanks for the HOW TO
For Step 16:
What does "damage" mean in this case? I have one of these that I was attempting to clean, so I lifted the battery power connector up, but I can't swear it didn't make contact. When I was trying to lay it down flat I thought it would stay flat until I put the screw in, but it popped back up a short way. I then held it down & put the screw it - now my MBP isn't powering on. Did this damage the logic board?
Nevermind my prior; took it to a local shop & they said it has liquid damage on logic board. Sending back to seller.
Woo hoo! Just finished. I don’t know who could do this battery repair on the quicker side of that range—mine took over 5 hours. Granted, I also redid the thermal paste on my CPU and my GPU. In addition, the old battery was really stuck in there, so that took extra time. Nonetheless, now I have more experience and, no need to buy a new computer ! Thanks, iFixIt !
Carsten did an excellent job in providing the correct information to do the job. But let us ALL NOT FORGET, this convoluted way of replacing a battery (something that would be considered a common and ordinary everyday routine need) is Apple's good faith attempt at preventing the everyday consumer from replacing their own battery in their own device. Take for example myself when it takes 80+ steps to change a battery, and provided I were wealthy, I'd have someone replace the battery for me. Not everyone is wealthy or similarly situated. Make sure you don't forget to encourage your elected officials in the U.S. Congress to vote to allow us Americans our right to repair our devices ourselves without long, drawn out, encumbering, and convoluted ways of doing it. Can you imagine how blinded in the night we would be if we had to go through all this just to change the batteries in our flashlights? We're no longer in the dark ages. I for one, am not prepared to go back even if Apple likes it or not.
Is there a way to replace the battery without removing everything? I can just slide the big battery out of my Dell Latitude E6500 and pop another one in. However, can I replace the battery in my 2019 MBP 16" without having to remove everything?
The repair guide is awesome. Unfortunately, replacing the battery didn't bring the machine back to life. Sadness!
But the repair guide was great. I felt very confident throughout.
Same with me. Did you figure out what was wrong with your machine? Replacing the battery was my best guess at what was wrong with my machine and now I'm stuck. Hopefully you had some luck diagnosing your issue?
Josef A -
Excellent guide
If I replace the battery, why coconut tool said that the manufacture date is 2013-03-18, is that normal?
So I just completed the whole sequence and everything went fine, really really well done Carsten! Only thing that went wrong is minor but still annoying: it seems I broke the left keyboard backlight cable. What to do in such a case?
Little extra onfo: I can't seem to find that part anywhere, and I can see the ribbon is slightly ripped in its angle, which must have happened when I put the logic board back in place. I can live without it, but it is strange having a keyboard lit only on one side... so any hint will be appreciated.
Yann,
Thank you for the kind words! Unfortunately, the keyboard, keyboard backlight, and their cables are integral to the laptop's upper case.
So thankful for this guide. Was able to resurrect an old unit that was collecting dust. Knew issue had to be the battery. Yes, a lot of steps; though, followed closely, you will succeed!!
3hours, with precaution and coffee time. All step are not so complicate. The unique attention is for the batterie removal. And cleaning step. So thanks for this tutorial.
Really thank you Carsten for this majestic guide, but shame on Apple for doing this job. I spent like 8 hours for doing everything (I know, I'm quite slow) and I even punctured the old battery while using the plastic card. I was a nightmare.
Hopefully, we will have easy-to-replace batteries by 2027 thanks to the European Union.
Special thanks to the Italian translators too, Grazie!
Do you seriously have to disconnect everything from power before removing the battery or can you just disconnect the battery and replace it with a new one? That just seems excessive.
But if their is a reason, I’d love to know
Is there any way to test if I'm having a battery issue? Can I boot the computer if I disconnect the battery? Currently the computer is completely dead and gives no sign of life what ever I do.
As everyone else commented - excellent guide. I got through everything, powered it up, and everything seemed great. At this point it was late and I went to bed. The next morning, after logging in, the screen went black - never to power up again. The battery data cable showed some signs of overheating. Everything looked aligned, oriented correctly, etc. I must have had the cable slightly rotated in the socket or something. Not sure it is worth retrying with another battery data cable. Anyone else have a similar issue?
Is this step necessary? I can’t perform this step as I am attempting to repair water damage and need to remove logic board & most likely replace the battery.
Macrepair SF - Reply
@mac_medic You definitely don’t want the power coming on while the board is wet. In your case, I think powering on the machine to disable Auto Boot would do more damage than it prevents. I agree, skip this step and be prepared to disconnect the battery quickly if the laptop automatically powers on. Good luck!
Jeff Suovanen -
Thats right! You don't want power running while working on your logic board.
Dan -
This did not work when running High Sierra.
Kyle B - Reply
Tried this on a 2018 MBP 13” Touchbar (there’s no iFixit guide for this model yet). Need to replace a broken screen.
Luckily I managed to connect to an external screen (Cmd-Down Brightness to switch displays) and enter above command. Seems to work, but there’s another problem with this model - it powers up as soon as any key is pressed……. ffs <gnashes teeth>
Cool_Breeze - Reply
I unscrew the battery first and wrap electrical tape over the logic board battery connector before attempting any repairs to the board. Haven’t had any problems yet and I’ve worked on about 10 of these models already. Also when you open the bottom case use a suction cup at the bottom and pull up then run a plastic spudger along the edges to disconnect the clips. Also only use a plastic spudger on the board. Saw a youtube video from a repair shop and he did not disconnect the power and used all metal tools during the entire process of removing the board. His last step was to disconnect the battery terminal.
Brian - Reply
Is this step necessary if my mac can turn on? Battery fully dead(
Nursat b - Reply
BEFORE YOU START: The included torx head stripped off before I was done (and you might need an additional T4) so stop now and go buy a good one. Also they fail to warn you above to get some blue threadlocker ahead of time.
Jason Sherron - Reply
This command did not work for me and I read that sometime in later 2020 Apple stopped this command from working…any ideas on a work around?
Patrick Machacek - Reply
Not able to do that with damaged screen
richardjgreen - Reply
If you have a damaged screen you can still use a converter from thunderbolt (USB 3) to HDMI and plug your Macbook Pro to your TV as monitor display. Just make sure to chose the right Source (HDMI IN) in your TV. I did it and to make it work I unplug and plug again in my Macbook and so I could disable the Auto boot
Roberto Sanchez Bustos -
Hi. This does not work on 2018 13” MacBook Pro with Touch Bar. I did exactly this to disable auto boot. But when I check by using nvram -p it says: auto-boot true. Am I doing something incorrectly? I did everything step by step. Copied and pasted the sudo command, pressed enter and then entered my password. I have Big Sur 11.1 installed. Is there any other way since I need to replace the screen. Thank you. Adrian
Adrian Vizik - Reply
Hi everyone. This is also a little pointless if you can’t see anything on the screen, and you don’t have a display adapter to USB C to display it. I agree with Brian about removing the back and disconnecting the battery cable before you even think about opening the lid of the MacBook. Applying the insulation tape is also a handy little tip that just makes sure there is no way to discharge from either the board or battery.
Roberto Enrieu - Reply
running `nvram -p | grep 'AutoBoot'` in terminal verifies that it was accepted
result: `AutoBoot %00`
Marek Polák - Reply
Running Big Sur 11.6.7 on a 2019 16" MBP, it's "auto-boot". So it's:
nvram -p | grep 'auto-boot'
to display the current state, the default istrue
- and then to change it,sudo nvram auto-boot=false
which turns it off.Ed Mechem -
This step is completely unnecessary if you follow the guide to disconnect the battery properly. Just put some tape between the battery and logic board connection to prevent it from accidentally touching and therefore powering on the laptop.
Grant Ormsby - Reply
It took me a few tries to make this command work, as I was able to copy and paste the command into Terminal, but could not type in my laptop’s password. I finally typed my password into a text document, copied it (command C), and then pasted it into Terminal and it worked.
tommy404 - Reply
I didn’t do this. Mine never auto-booted before I replaced the battery. Now it does.
hatuxka - Reply
BEFORE YOU DO ANYTHING - CHECK THE BATTERY!
I-fixit sent me a bad battery, which I didn’t realize until it was already install. They sent me a new one, but I wasted hours uninstalling and reinstalled.
Get a volt meter and measure the voltage on the output of the battery pack. If it reads 0 V, SEND IT BACK. It should read over 2 V.
bcardanha - Reply
I've just received my replacement battery and it reads 0,042V between the two main connectors. Do you think it's dead?
peter sussex -
When I did this from Terminal.app within Recovery Mode, the “sudo” was not recognized but I could invoke it without the sudo part. It seems to have been accepted when looking at “nvram -p”
johann beda - Reply
When in Recovery Mode, you already have superuser powers. So you don't need to prefix commands with the sudo command to invoke them with root privileges; you already have them. Do a
pwd
(print working directory) after opening Terminal in Recovery Mode, and you'll see that you're in the root user's directory.Ed Mechem -
I received the battery kit for my 2018 MacBook Pro and as per the above comment from bcardanha - Oct 12, 2021, I checked the voltage on the pads marked + and - . It was zero volts so I panicked a bit.
I sent a message on the iFixiT Facebook page and I got no reply. I finally found the customer service email for Ifixit Europe and sent them an email voicing my concern as I was not keen to work for couple of hours just to discover that the battery is faulty. I had an almost instant reply on the email (kudos to them) and they adviced me to go ahead and install the new battery as the voltage measured when battery is not connected is not relevant.
I took a leap of faith and after two hours… the new battery showed 50% charge and everything seems to be working just fine. I am happy it worked.
Mircea Comanici - Reply
After removing the old battery and installing the new battery I powered up the MBP before screwing the bottom on. I discovered the my keyboard would not function. It took a few hours of investigation and frustration that I discovered the track pad power ribbon had become partially dislodged from the trackpad. I was able to see that this through the little machined slot where the battery sat. I had to remove the trackpad to reinsert the power ribbon back into the connector in the trackpad. after reassembling and reinstalling the battery etc the keyboard worked. Just food for thought if your run into the keyboard issue.
Ed Mease - Reply
This should be the default. IMO I tell you to power on - not the lid.
G Sena - Reply
Est ce que cela fonctionne sur un macbook pro 2017 sans touchbar ?
maël muzelet - Reply
Bonjour Maël, oui, ce tutoriel concerne "les MacBook Pro 2016 (et plus récents) et les MacBook Retina 12" 2017 (et plus récents)"
Claire Miesch -
Excellent instructions. I was able to follow and install the new screen. I recommend that you get a good set of tools before you begin. I started with an inexpensive repair kit bought online. The Penta and torx bits failed. I bought an IFIXIT kit with quality bits and I was able to do everything I needed.
Tom Markham - Reply
If you're not running an admin account the sudo command won't work (which honestly, you should not be running admin). Rather than logging in to your admin amount via the OS, in the terminal type "login [admin username]," then the password and you'll be able to do the sudo command as described above. Once you're complete, type "logout [admin username]" and you'll be good to go. Obviously replace [admin username] with whatever the account name for your admin user is.
arichard2401 - Reply
For those unable to complete this step because the screen is too damaged I recommend leaving your macbook on until the battery dies.
Nicholas R Licato - Reply
Just replaced my 2018 15" MBP battery. Running Sonoma.
I found no way to disable AutoBoot (The status can be checked in the Power section of system report).
Anyway, i left my battery completely drain before opening the MBP, and had no issues during the process.
Cédric Bontems - Reply
After sending this command in terminal when I checked what happens if I now open the lid, instead the screen lit slightly up (still black) then a battery symbol showing the charging state showed up.
Now, after replacement of the battery, this is all I get to see.
No reset of NVRAM nor PRAM helped.
Currently the new battery charges (58% atm) and it feels like it‘s mocking me.
webrockers - Reply
I suspected the keyboard or TouchID sensor wouldn’t work, so I went on and checked every connector.
I missed connecting the left TouchID sensor from step 31.
webrockers -
