Introduction
Replacing the upper case requires the removal of nearly all the components found within your MacBook Pro.
Remove the following ten screws securing the lower case to the upper case:
Seven 3 mm Phillips screws.
Three 13.5 mm Phillips screws.
Using both hands, lift the lower case near the vent to pop it off two clips securing it to the upper case.
Remove the lower case and set it aside.
Tool used on this step:P6 Pentalobe Screwdriver 2009 15" MacBook Pro Battery$5.49
Remove the two 5-Point Pentalobe screws along the top edge of the battery.
Use the tip of a spudger to bend back the finger of the "Warning: Do not remove the battery" sticker while you remove third five-point Pentalobe screw hidden underneath.
Lift the battery by its plastic pull tab and slide it away from the long edge of the upper case.
Tilt the battery back enough to access the battery cable connector.
Pull the battery cable connector away from its socket on the logic board and remove the battery from the upper case.
Remove the three T6 Torx screws securing the left fan to the logic board.
Lift the fan out of the upper case.
Lift the left fan out of the upper case.
Hold the end of the cable retainer down with one finger while you use the tip of a spudger to slightly lift the other end and rotate it away from the camera cable connector.
Disconnect the camera cable by pulling the male end straight away from its socket.
Use the flat end of a spudger to pry the optical drive cable connector up off the logic board.
Using the flat end of a spudger, pry the subwoofer connector straight up from the connector jack.
Use the flat end of a spudger to pry the hard drive/IR sensor cable connector up off the logic board.
Remove the two 1.5 mm Phillips screws securing the cable cover to the logic board.
Lift the cable cover out of the upper case.
Use your fingernail to flip up the locking flap on the ZIF socket for the keyboard ribbon cable. The locking flap is located at the opposite side of the socket compared to the keyboard ribbon cable. Hook your fingernail under it and carefully lift it up vertically.
Use the tip of a spudger to slide the keyboard ribbon cable out of its socket.
Remove the single 7 mm Phillips screw securing the display data cable retainer to the upper case.
Remove the display data cable retainer from the upper case.
Grab the plastic pull tab secured to the display data cable lock and rotate it toward the DC-in side of the computer.
Using the tip of a spudger, flip up the keyboard backlight ribbon cable retaining flap.
Pull the keyboard backlight ribbon cable straight out of its socket.
Remove the following screws:
Seven 3.3 mm T6 Torx screws securing the logic board to the upper case.
Two 8 mm T6 Torx screws securing the DC-In board to the upper case.
Carefully lift the logic board assembly from the left side and work it out of the upper case, minding the port side that may get caught during removal.
Lift the logic board enough to gain clearance and use a spudger to pry the microphone up off the upper case.
Slide the logic board away from the port openings and lift the assembly out of the upper case.
Remove the two Phillips screws securing the hard drive bracket to the upper case.
Remove the hard drive bracket from the upper case.
Using its attached tab, lift the free end of the hard drive and pull it away from the edge of the upper case.
Pull the hard drive cable connector away from the body of the hard drive.
Remove the hard drive and set it aside.
Carefully peel the hard drive cable off the adhesive securing it to the right speaker housing.
Remove the following four screws securing the hard drive and IR sensor cable to the upper case:
Two 1.5 mm Phillips screws.
Two 4 mm Phillips screws.
Carefully peel the IR sensor/sleep light ribbon cable off the adhesive securing it to the upper case.
Disconnect the Bluetooth cable by pulling the male end straight away from its socket.
Use the flat end of a spudger to carefully pry the AirPort antenna off its socket on the AirPort card.
Remove the two 8 mm Phillips screws securing the Bluetooth/camera cable retainer to the upper case.
Lift the AirPort board/cable retainer assembly out of the upper case.
Remove the single 3.5 mm Phillips screw securing the inner side of the optical drive to the upper case.
Remove the two 3.5 mm Phillips screws securing the outer side of the optical drive to the upper case.
Remove the following four screws securing the subwoofer and right speaker assembly to the upper case:
Two 3.2 mm Phillips screws.
One 2.6 mm Phillips screw.
One 5 mm Phillips screw.
Remove the two 8 mm Phillips screws securing the camera cable retainer to the upper case.
Lift the camera cable retainer out of the upper case.
Remove the outer two T6 Torx screws securing both display hinges to the upper case (four screws total).
Open your MacBook Pro so the display is perpendicular to the upper case.
Place your opened MacBook Pro on a table as pictured.
While holding the display and upper case together with your left hand, remove the remaining T6 Torx screw from the lower display bracket.
Grab the upper case with your right hand and rotate it slightly toward the top of the display so the upper display bracket clears the edge of the upper case.
Rotate the display slightly away from the upper case.
Lift the display away from the upper case, minding any brackets or cables that may get caught.
