Introduction
When replacing your hard drive, you must transfer the Torx screws from the old drive to the new one.
With the case closed, place the Unibody top-side down on a flat surface.
Depress the grooved side of the access door release latch enough to grab the free end. Lift the release latch until it is vertical.
Grab the translucent plastic tab and pull the battery up and out of the Unibody.
If the latch is depressed it will lock the battery in place.
Remove the single Phillips screw securing the hard drive bracket to the upper case.
Lift the hard drive by its pull tab enough to grab and remove the retaining bracket.
Lift the hard drive out of the upper case, minding the cable attaching it to the computer.
Remove the hard drive from its cable by pulling the cable connector straight away from the drive.
