This translation may not reflect the most recent updates from the source guide. Help update the translation or view the source guide.
Introduction
使用本指南更换坏掉的电池。如果你的电池鼓包了,请采取额外措施。
使用电池顶部的塑料拉手拉出电池。
把电池充满,然后至少继续充电两个小时。之后,像往常一样使用它,消耗电量。当你看到低电量警告时,保存好你的工作,然后让笔记本开着,直到它因为低电量而入睡。再等待至少五个小时,之后再把你的笔记本充满到100%
如果在安装新电池后你发现了一些异常状况或麻烦,你可能需要重置你的Macbook的设备管理器
把你新安装的配件和原始配件进行比较——你可能需要转移剩余的配件或者移除新配件背后的黏胶。
按照本指南相反步骤来重新组装设备。
如果你发现新电池有任何问题,你可能需要重置你的 MacBook Pro's SMC.
把电子废料带到 R2 或 e-Stewards 认证的回收商.
维修未按计划进行?请查阅论坛 来排除障碍。
按照本指南相反步骤来重新组装设备。
393 other people completed this guide.
Special thanks to these translators:
85%
These translators are helping us fix the world! Want to contribute?
Start translating ›
41 Comments
I'd say this difficulty should be rated as easy, not moderate - it's well written and easy to follow, and documents one of the more simple procedures.
I think they rate it as "moderate" for needing to acquire the "Y" type screwdriver, but, (and here's a protip for first timers...) A small straight-blade actually fits and turns the screw as normal, with no need for special tools. :)
pyrodice -
