Introduction
Use this guide to replace the entire display assembly on your MacBook Pro, in order to fix a cracked or faulty screen. This assembly also includes the integrated ribbon cables that are known to fail as part of the “FlexGate” defect, so replacing it will also resolve the “stage lights” effect and other issues resulting from ribbon cable damage.
For your safety, discharge your MacBook Pro's battery below 25% before you begin. A charged lithium-ion battery can create a dangerous and uncontrollable fire if accidentally punctured.
Power on your Mac and launch Terminal.
Copy and paste the following command (or type it exactly) into Terminal:
sudo nvram AutoBoot=%00
Press [return]. If prompted, enter your administrator password and press [return] again. Note: Your return key may also be labeled ⏎ or "enter."
sudo nvram AutoBoot=%03
Tool used on this step:Magnetic Project Mat$19.95
Close the display and flip the entire laptop upside-down.
Use a P5 Pentalobe driver to remove six screws securing the lower case, of the following lengths:
Four 4.7 mm screws
Two 6.6 mm screws
Press a suction handle into place near the front edge of the lower case, between the screw holes.
Lift up on the suction handle just enough to open a small gap under the lower case.
Slide the corner of an opening pick into the gap you just created underneath the lower case.
Slide the opening pick around the nearest corner and then halfway up the side of the MacBook Pro.
Repeat the previous step on the opposite side, using your opening pick to release the second clip.
Lift the front edge of the lower case (the side opposite the display hinge) just enough to slide your fingertips underneath and get a good grip on it.
Pull the lower case firmly towards the front of the MacBook (away from the hinge area) to separate the last of the clips securing the lower case.
Pull first at one corner, then the other.
Remove the lower case.
Set it in place and align the sliding clips near the display hinge. Press down and slide the cover toward the hinge. It should stop sliding as the clips engage.
When the sliding clips are fully engaged and the lower case looks correctly aligned, press down firmly on the lower case to engage the four hidden clips. You should feel and hear them click into place.
Peel up and remove the large rectangular battery board cover, on the edge of the logic board nearest the battery.
If the cover doesn't peel up easily, apply mild heat with an iOpener, hair dryer, or heat gun to soften the adhesive underneath, and try again.
Use a spudger to gently pry up the locking flap on the ZIF connector for the battery board data cable.
Disconnect the battery board data cable by sliding it out from its socket.
Slide parallel to the logic board, in the direction of the cable.
Use a T5 Torx driver to remove the 3.7 mm pancake screw securing the battery power connector.
Use a T3 Torx driver to remove the two 3.5 mm screws securing the cover on the display board flex cable.
Remove the display board flex cable cover.
Use a T3 Torx driver to remove the two 1.7 mm screws securing the bracket for the display board cable connector.
Remove the bracket from the display board cable connector.
Use a T3 Torx driver to remove the two 2.0 mm screws securing each hinge cover (four screws total).
Disconnect all three antenna cables by prying each one straight up from its socket.
Slide your tweezers or the flat end of your spudger underneath each cable until it's near the socket, and then gently twist or pry up to disconnect it.
Use a T5 Torx driver to remove the four 3.3 mm screws securing the display board.
Make sure the display board flex cable lies on top of the board, not trapped underneath.
Use a P2 Pentalobe driver to remove the sixteen 1.5 mm screws securing the antenna assembly.
Carefully remove the antenna assembly, while simultaneously feeding the antenna cable bundle out from underneath the heat sink.
Use a T3 Torx driver to remove the four 3.9 mm screws securing the display cable cover springs.
If you plan to re-use your screen, open it and apply a piece of tape to the glass directly above each hinge. This helps protect the glass from getting scratched in the following step.
Fully open the screen and stand your MacBook Pro up on one side.
Use a T8 Torx driver to remove the two remaining 4.9 mm hinge screws (one from each hinge).
Remove the topmost screw last, using one hand to steady both halves of the MacBook Pro to make sure they don't separate and fall over unexpectedly.
Push both halves of the MacBook Pro together so that the hinges can be lifted clear of their recesses in the chassis.
Push the main body of the MacBook Pro away from you while pulling the screen toward you to separate it.
