MacBook Pro 15" Retina Display Mid 2012 SSD Replacement
  1. MacBook Pro 15" Retina Display Mid 2012 SSD Replacement, Lower Case: step 1, image 1 of 1
    • Remove the following P5 pentalobe screws securing the lower case to the MacBook Pro:
    • Eight 3.0 mm
    • Two 2.3 mm
  2. MacBook Pro 15" Retina Display Mid 2012 SSD Replacement: step 2, image 1 of 1
    • Lifting from the edge nearest the clutch cover, lift the lower case off the MacBook Pro.
    • Set the lower case aside.
  3. MacBook Pro 15" Retina Display Mid 2012 SSD Replacement, Battery Connector: step 3, image 1 of 1
    • Peel back the warning label covering the battery connector.
  4. MacBook Pro 15" Retina Display Mid 2012 SSD Replacement: step 4, image 1 of 2 MacBook Pro 15" Retina Display Mid 2012 SSD Replacement: step 4, image 2 of 2
    • Using the flat end of a spudger, gently pry the battery connector straight up out of its socket on the logic board.
    • Bend the battery cables back and out of the way, ensuring that the battery connector doesn't accidentally make contact with the logic board.
  5. MacBook Pro 15" Retina Display Mid 2012 SSD Replacement, SSD: step 5, image 1 of 1
    • Remove the single 3.1 mm T5 Torx screw securing the SSD to the logic board.
  6. MacBook Pro 15" Retina Display Mid 2012 SSD Replacement: step 6, image 1 of 1
    • Slightly lift the leftmost side of the SSD and firmly slide it straight away out of its socket on the logic board.
Jake Devincenzi
117,301 Reputation
57 Guides authored
Past 24 Hours: 13
Past 7 Days: 139
Past 30 Days: 672
All Time: 340,380
