MacBook Pro 15インチ Unibody Mid 2009 RAMの交換
  1. MacBook Pro 15インチ Unibody Mid 2009 RAMの交換, 底ケース: step 1, image 1 of 1
    • 底ケースを固定している以下の10本のネジを外します。
    • 3 mm プラスネジー7本
    • 13.5 mm プラスネジー3本
  2. MacBook Pro 15インチ Unibody Mid 2009 RAMの交換: step 2, image 1 of 2 MacBook Pro 15インチ Unibody Mid 2009 RAMの交換: step 2, image 2 of 2
    • 両手を使用して排気口の近くから底ケースを持ち上げて、上部ケースに固定している2本のクリップを外します。
    • 底ケースを取り外して脇に置きます。
  3. MacBook Pro 15インチ Unibody Mid 2009 RAMの交換, RAM: step 3, image 1 of 2 MacBook Pro 15インチ Unibody Mid 2009 RAMの交換, RAM: step 3, image 2 of 2
    • RAMから各タブを同時に押し出して、チップ両側にあるタブから外します。
    • このタブがチップを固定しています。タブを外すと、チップが"飛び出します"。
    • RAMチップが外せたら、まっすぐソケットから引き抜いてください。
    • 2番目のRAMチップがインストールされている場合は、この手順を繰り返してください。
デバイスを再組み立てする際は、これらの手順を逆の順番に従って作業を進めてください。
159 other people completed this guide.
Special thanks to these translators:
en jp
100%
Midori Doi is helping us fix the world! Want to contribute?
Start translating ›
5 Comments
I bought and installed 4GB x2 RAM for my Mid 2009 15 inch MacBook Pro and it was easy and is working great. Before this I had 4GB and it was being maxed out. It was very easy. I did purchase the required tools which made it simple. I also swapped the battery at the same time. I am writing this from the same computer and it is working well. Good luck!
1tom2go - Reply
I had no trouble installing the 4 GB RAM I bought for my Mid 2009 15 Inch MacBook Pro. The mistake I made though was not realising that my machine has two RAM slots. I only bought one chip! So now I have to buy another one.
If you read this before you buy some RAM, make sure you check how many slots your computer has!
Also, I must say the customer support from ifixit is great. I messaged them about this and some other issues I was having and I got a detailed response from them within a couple of days. Thanks guys!
oliverbarrand - Reply
Thanks! You saved my life.
saltyhf - Reply
I replaced my original 2x 2gb ram with 2x 4gb RAM following your instructions. However, upon boot up, it’s only showing 1 of the 2 4gb chips. Any tips on how to get both seated correctly?
Matthew Longo - Reply
Never mind. I was able to pop the second chip back out and get it seated properly.
Matthew Longo -
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 46
All Time: 61,627
