Introduction
Use this guide to replace the Retina display, display glass, and iSight camera assembly.
Remove the following ten screws securing the lower case to the upper case:
Two 2.3 mm P5 Pentalobe screws
Eight 3.0 mm P5 Pentalobe screws
Wedge your fingers between the upper case and the lower case.
Gently pull the lower case away from the upper case to remove it.
Agreed. A decent amount of force is required here.
To reattach bottom case I found it helpful to line fingers up with clips under case should snap easily
Easy snapped off for me
Popped off of the bottom case for me. My batteries were dangerously inflated
What is the black vinyl-y sticker on the inside of the case (some sort of shield?). I was forced to slightly puncture it in order to replace the feet on my laptop. Thanks in advance.
When I got the back off, I found this piece loose, any idea what it is? about 9mm long frosted plastic
I took my pointer and thumb (which are luckily long enough) to feel where the studs are on the back panel, and then as I put the back panel back on, I pushed in the spot I had marked with my fingers to ensure I was applying pressure only on this part.
Can you make a youtube video showing the steps? I am not sure how to proceed with this step. I want to see it done.
Thanks.
My new battery kit included a replacement for this part, so, no need to save the old one.
The aux in my mac works 1 out of 10 times , Is this relevant to me in order to solve the proplem ? I cant see aux input on the io board ?
A plastic foam cover also covers plug and socket and the whole battery. It is easy to remove it from the right side to the trackpad wire that the battery plug is free like shown in the picture. I kept it to use it again later.
Use the flat end of a spudger to lift the battery connector straight up out of its socket on the logic board.
I have a friends MacBook Pro that has some water damage that caused the MacBook not to be able to use battery power, but still work when plugged into A/C. Upon further inspection I can see visible corrosion on a few of the 9 cables going from the battery connector to that small circuit board. Is it possible to just replace that circuit board?
I have the some problem. I was thinking to replace the whole battery but I am not it will solve the problem. Any suggestions?
Sometimes it can be enough to just clean the contacts without having to replace the entire board. Dosent work for complicated IC's like plcc type, where corrosion is underneath the chip. Here you will have to reheat and reapply the IC.
Hi,have you find the solution for your battery? I also have same problem, run with plugs but it battery not supporting… as soon the plug of it goes off
Have either of you replaced the battery and/or circuit board to fix the MacBooks with the water damage ? I have the same problem with the MacBook working fine when connected to power but dying immediately when the power cord is removed.
Hi, Steve. I had the same problem: Macbook Pro 15 retina with coffee damage. And it worked fine when connected to power. I made it working after replacing the whole battery. It seems that circuit connected to the battery becomes disabled to prevent short circuit.
When placing the battery connector back into the socket on the logic board, check that every part of connector is pressed down. You should hear a soft click when it's back in place.
Thanks for the comment. My MBP isn’t powering on after I walked through these steps, and I assume it is because the battery connector isn’t fully connected. (I can’t check yet since I borrowed the pentalobe screwdriver)
+1
I thought I made sure it was connected but when running the computer it only detected the battery but couldn’t power it. I had to run with power adapter. Also it didn’t charge. I guess some pins were connected but not all. To verify that all were connected I removed the plastic cover, placed it carefully completely flat, and then reattached the plastic cover. After that it worked!
If I only want to replace the trackpad cable, then which steps should I skip? This step seems unnecessary
This step is not unnecessary because you need to remove the battery before you can replace the trackpad
I replaced both my L and R speakers on my MBP mid-2014 13” withOUT doing this step.
I did the same thing, probably unnecessary to disconnect the battery. I’m not a technician however.
I have verified I have this battery, and I have a mid-2014 macbook retina. And I swear i do not see this battery connector. I didn’t take the cover off, per other comments that said it was an unnecessary risk. What the heck? will I not see the battery cable without taking of that cover?
ooops nevermind..I see it now! tks . But..there is SO much gunk/dust under there (old, hand me down, used by my teen daughter while eating in bed no doubt!) . Should I attempt to clean? Beyond just blowing on it? Is compressed air safe? Or should I just leave it be? Assuming I don’t break it while replacing this battery I’d like not to break it otherwise! tks
Lift from the long, flat side, not the shorter side. In this picture, you should lift from the NORTH part of the connector, not the WEST side like they are doing. This is because you can spread the pressure from lifting the connector across more area, as compared to the side. I accidentally broke off part of my battery connector lifting it up the way shown, but was able to do it the way I described without problem. Make sure to lift from the wide part so you don’t have my same trouble!
If you miss or let this step for later like I did, the power left in the battery even though the computer is completely shut down, will screw up the I/O board cable like I did. I noticed this after I put all the pieces back, turn the computer on and surprise, no wifi hardware is detected. -.-
Not sure I understand: did leaving the battery plugged in permanently broke the I/O board (or anything else)?
Adrien -
That’s a great idea!
I agree that inserting a small paper above between the socket and the connector was useful. I used post-it-note, but kept the adhesive away from the socket.
Carefully remove the rubber fan bumper from the edge of the heat sink.
I forget to put the fan bumper back . Now I am unable to open the two screw . Can I leave it as it is or I have to take it to professionals
Insert the tip of a spudger under each of the antenna cables near their connectors and pry up to disconnect them from the AirPort board.
Connect the long-sleeved cable to the center socket.
The short-sleeved cable connects next to the screw.
The remaining cable has no sleeve, and connects in the last empty socket, next to the fan.
I struggled with reconnecting these, and in the process accidentally ripped the connector away from the wire. Is there anything I can do to reattached it?
When reassembling, I used tweezers to line them up and the spudger to push them down.
thank you Joshua, this helped me get them. they do take a bit of patience but it’s worth taking your time.
I saw the sleeves on these.. and when looking at the replacement display saw they matched exactly and took the chance it was intentional. The only thing that got me.. was the bottom panel screws.. didn't know there were 3 types.. (should have known though, I mean right?! LOL Apple (rolls eyes) They could do like Samsung and use one screw for everything.. but oh no.. there is some OCD engineer that just likes SCREWING with people!
Pro Tip: When reassembling, do not screw on the metal tab attached to these connectors (part of step 15) until after you have all 3 connected. This gives you uninhibited range of motion for the 3 wires. Go slow as other commenters have said. Start with the shortest wire first. Once all 3 are connected, screw on the metal tab with those 2 screws. Finally double check that all 3 are still connected.
I found an alternative method. That is NOT to disconnect these three tiny wires but instead, leave them attached to the AirPort board and remove the AirPort board itself and let it dangle safely to one side with all three antennae cables attached.
@macnb, if you’re replacing the display, which is what these instructions are for, then you *must* disconnect these wires, as the new display includes new ones!
Yes you are correct WHEN replacing the WHOLE display/LCD.
In my case I was ONLY replacing the LCD display CABLE. So in my case it was not necessary to remove the wireless antenna (since I was not replacing them).
Use the tip of a spudger to push on either side of the the iSight camera cable connector to walk it out of its socket on the logic board.
First, lift the flat cable just off the board as it is normally “stuck” to the board. This will help the connector to release from the socket.
Ripped cable from logic board? Step 9.5
Grab the black plastic tab to flip the display cable connector open and pull it straight out of its socket on the logic board.
Please use a nylon black stick to lift the lock bar up and push the connection apart reason being is the lock bar should not be pulled on and by pulling on it like shown may cause damage to the MLB/DISPLAY connection and then you’re into not just a display repair but a MLB on top of it!!!
hello, im trying to do this because im experiencing a blackscreen problem. Id like to do this but my macbook looks so different than this one. Could anyone help me?
If it doesn’t look like this, you’re looking at the wrong guide.
Remove the two 4.2 mm T5 Torx screws securing the aluminum hinge brackets on either side of the Macbook.
I found these to be very tight and wasnt able to move them with the ifixt screwdriver kit, i had to get a t-handle torx 9 bit to move them
Yes they were tight but I managed to shift them with the iFixit screwdriver set
The T5 in the set I bought from LaptopScreen.com was too big and started to strip these screws. Got an Ace Hardware brand one instead and it worked great.
Be careful at reassembling. This screw tends to brake if you tighten it too much.
These were T4 not T5 size for me
Use a pair of tweezers to lift aluminum hinge brackets off the right and left display hinges.
Vorsicht beim Wiederzusammenbau! Diese Schraube ist bei mir am Kopf abgebrochen, als ich sie etwas zu fest hineingedreht habe. Musste das Teil dann notdürftig mit Klebeband fixieren.
Remove the four outer 5.3 mm T8 Torx screws (two on each side) securing the display to the upper case.
Does these three screws are the same size? Can i mix use these screws during the installing process?
On my model, there was a thin piece of translucent plastic covering the left-side outer screws. It peeled off easily. It must be replaced upon reassembly. When removing these two (left-side) screws, a metal assembly securing the antenna wires was released below the screws. It must be replaced before reassembling these two screws.
The translucent plastic on those screws is the adhesive that holds the rubber hinge covers in place. Sometimes it stays attached to the hinge cover, sometimes it stays on the screws.
Grab the upper case with your right hand and rotate it slightly clockwise, toward the top of the display, so the display brackets clear the edge of the upper case.
Rotate the display slightly away from the upper case.
Pull the display away from the upper case, minding any brackets or cables that may get caught.
Yes also found the hinges to be extremely tight, could not move them with from their initial position with fingers, ended up using a pair of pliers to rotate them enough to get fingers under them
Are there any cheaper replacement screens? If so I need to know. My parents still haven't found out and I don't make a ton of money...
Excellent guide, Andrew! I am an ACMT and when disconnecting the eDP cable, I like to use the pointed ends of two spudgers (Apple calls them ‘black sticks’) to push the connector straight back out of the socket by pushing on its edges. This prevents any stress to the locking bar and also helps to ensure that the connector is disconnected evenly. For reassembly, I line up the connector carefully and once the pins are all lined up and the cable connector partially inserted, I push on the back edges on either side of the connector with the pointed ends of two spudgers, ‘walking’ the connector back into place so that it is even on both sides.
Also, when disconnecting the camera cable connector from the logic board, I use the same method as above, situating the points of the sticks into the notches on each side of the connector and pushing straight back vs walking it back. I do the same thing when reconnecting the cable, but I ‘walk’ it back as mentioned above with the eDP cable connector.
Also, once I have removed the clutch covers, I remove the two screws holding the metal antenna grounding loop in place (first picture in Step 15 of your guide). I move the loop out of the way and reinstall the two screws just until the heads of the screws make contact with the metal surface of the hinge. I loosen all of the rest of the screws and then tighten them back down just until the screws stop turning (without torquing them). I thoroughly brush off the surface area of the ESD mat where I am going to situate the MacBook for the next step, and then flip it over and open the display 90 degrees. I flip the machine back over and rotate it 90 degrees so that the ‘Apple’ logo on the back of the display lid is facing me, inverted, and the display hinges are much closer to me. After carefully scooting the machine back just until the display makes contact with the edge of the table, I pull the display up toward me to open it fully. I then carefully remove the hinge screws.
For removal, you simply need to lift up slightly on the top edge of the display (possible once the 6 hinge screws have been fully removed) until it has cleared the recesses of the top case. It can then be lifted out without any hassle and you should not need to use any paper clips as mentioned in previous comments. I hope this helps someone; it is knowledge I have gained from following Apple’s Service Guides and experience from having replaced hundreds of displays in a short amount of time. We are an AASP on a university campus, so display repairs are VERY common (from mostly student customers).
Hello everyone! I have problem after display changing. The brightness adjustment doesn’t work anymore. As I fine out its standard situation when you change displays for MacBook. Did anyone know how to fix this issue ?
I'm having the exact same issue! Did you find a solution?
Excellent guide. My IT guys were scared to touch my mac but I did it myself. Thanks to ifixit
This is an excellent guide. I replaced the screen on my macbook pro 13” retina early 2015. However, I am having some odd behavior from my fixed computer.
With the lid open, the computer does not seem to boot. However, if I close the lid (after booting or re-booting) the apple logo lights up and when I open the lid fully, the computer operates normally. Any idea what is wrong? I bought the screen replacement second hand on ebay.
Am having the same issue.
evelez84 -
150 other people completed this guide.
28 Comments
I've been browsing guides to this model and I don't get how in this one on Youtube the laptop looks completely different, although it also claims to be A1502. Either one of them is a different model or I'm really missing something?
Unfortunately the A1502 number isn't an exclusive model number, several devices share it, the internal differences between them vary. The more telling number is the EMC number, which tends to me more exclusive to unique devices.
After a closer look they actually seem to be the same, I just got confused by the video being a lot less detailed than this walkthrough. I just replaced the screen of my macbook following this guide (yay!) without any previous experience of fixing macbooks, though I must admit I assembled a few desktops at the dawn of the millennium. The only slight problem I encountered was that the main display cable wouldn't lie flat enough in that corner, it kept sticking out, and even after screwing the lid on the gap at that corner seems to be a tiny bit wider. But the laptop is working anyway.
Thank you Sam for posting this guide! It saved me a lot of time and money. Being in China I bought the display assembly on Taobao for $250US whereas the shop repair estimate that I got was around $400.
If anyone is still having doubts - you can do it!
Can you replace just the LCD without the clamshell bezel and cables?
Kind of. In most laptops the lcd assembly is a separate unit that can be replaced. In these the top case serves as the lcd assembly.
But you can replace just the lcd polarizer. It is much more difficult than replacing the whole display assembly, as the diffuser panel which is directly behind the polarizer is very fragile.
This video provides a guide on how you can do it: https://www.youtube.com/watch?v=pOS-rjvn...
I managed to replace the display assembly pretty smoothly and got a cool video out of it! For anyone interested in watching a 2-minute time-lapse version, you can watch it here: (https://youtu.be/BHhpoG-0_oI)
Excellent guide! Completed it in about 20 minutes and everything works now!
Great guide, easy to follow.
Replacement display from iFixit had the brackets folded down towards the screen, had to unfold them carefully with pliers.
Take note - the black hinge cover (the bulge on the display assembly) shifts left and right. Make sure to adjust it dead center when assembling. Also make sure to align display with bottom case perfectly before tightening down the bracket screws.
good guide replaced my screen no major issues, reattaching the three small cables was the trickiest bit and definitely needed care.
A great guide, I spent around an hour to complete removal and install of new display (from iFixit), its cheaper than getting Apple repaired and results in a great quality fix, my daughter is over the moon. I chose the B grade screen and its great, not sure what scratches they are referring to :)
Followed this guide and mine turned out AMAZING. So happy I didn't spend the $500-$600 to have someone else fix it. Literally spent less than an hour to do it all. I would highly recommend buying the needed tools for it .
Am I wrong or it is not possible to replace the front-glass only (without the LCD), on the A1502 Model ? (late 2013) ?
I cannot find the front-glass for this model on the internet... any idea where I can find it ?
Brilliant guide as usual all done in half an hour. Worth noting that I could not adjust the brightness at first but a PRAM reset sorted that out nicely.
Thank you.
Just did the same repair.. I am also having display brightness issues but already tried PRAM and SMC resets. Brightness works under Bootcamp but not macOS... any ideas? A third party utility I downloaded allows me to control brightness but I really should be able to use the brightness adjustment keys. Lastly, the 1440x900 display resolution option is gone as well. Stuck with 1024x600 or 1280x800 (default but highest resolution option I have).
Step 15, Does these three screws are the same size? Can i mix use these screws during the installing process?
Thanks for the very detailed guide. Replacing the screen worked like a charm! But I have a problem: My screen does not turn on. I can hear the start-up sound but the display only shows a black light. By connecting an external screen via HDMI and closing the lid I can boot normally. I tried PRAM and SMC reset, but neither helped. I switched back to the old/half broken screen and it turned on normally. Any idea what I could do next?
Hi, it’s me again. I managed to make it work. It seems that one of the connectors were not connected in the right way. I did not do anything different but switched once back to the old screen and then to the new one again, and it is working. I suspect the one from step 11. I read in other forums that the display connector can be a problem. Thanks for this wonderful guide!
Sonopha -
Super Anleitung. Ich hab es auf den ersten Anlauf geschafft. Danke
This is a great guide! Managed to complete removing the display assembly in less than 20 minutes. Any leads on how to fix/replace a broken lcd? Can that be done? or does one need to replace the entire display assembly?
Many thanks for the detailed, careful instructions - and especially the clear, useful photos. Saved me a lot of money, and a lot of headache. Repair was clear and straightforward.
Hi,
can I replace an damaged display of a MacBook Pro 13” late 2013 with a display from the early 2013 version?
I compared the high-def pictures of each cable connection and they seem to be identical, or am I wrong?
Thanks for the help.
Cheers
L
For all the screws you use the P5 pentalobe screwdriver?
Carlos - Reply
Pentalobe is only for the screws on the bottom cover. The Torx screw driver is for the remainder.
Fredrik -
Is the Pentalobe screwdriver mentioned in the tools list? I did not have one so I used a filed down flat blade screwdriver. Not a fantastic idea, but it works.
Alex Birkett - Reply
Yes, it's mentioned on the top of this page. P5 Pentalobe to be precise. I didn't have one either, so I bought one from iFixit and that works fantastic. An absolutely precise fit, which is important especially when you might open your MacBook a couple of times during the years you own it. Not using the correct tool might do more harm to the screws than you want! I once had this with a Lenovo Yoga 3 Pro, which has Torx screws (T4 I think) and I used cheap Chinese quality tools, with the result that both the tool and one of the screws are damaged.
addvariety -
I never, ever, ever considered using anything but the correct tool on the Pentalobe screws. Too easy to strip and void your warranty (if still in effect), as well as make it almost impossible to get inside later for another upgrade or repair. The Wiha P5 Pentalobe screwdriver fits like a glove and costs only about $11 (a fraction of your drive's price)at Amazon.com. Get it!
marketing - Reply
is P5 supposed to be for all 10 screws? it works on the 2x 2.3mm at the top, but not for the 8x others for me. what size screwdriver for the 3mm? thanks
monsieurescargot - Reply
Yes, the p5 works for all 10 pentalobe screw heads for bottom cover. The the different size mm reference only refers to the difference in length of the screws, but again both heads are p5.
Antoine Thornton - Reply
I followed this exactly and was able to replace my broken trackpad. I did not have to replace the ribbon OR the battery. However I would suggest getting the ribbon since it’s fairly cheap, as for the batteries I was able to do it with a card only. I didn’t use any heat or the liquid but it takes some time. You really have to work the card in there to release the glue. Also you must be very careful not to bend the batteries or damage them, if you do you must replace with new. This took me about 1.5hrs and my computer works like new. Apple cost for this job was around $450, I did it for $120. Big ups to ifixit for this awesome tutorial, tool set and parts!
On a side note, only use quality tools, the cheap ones will break or strip the screws.
Dustin Steward - Reply
Note that the eight 3mm screws have a shoulder under the head, while the two 2.3mm screws are “full thread”, i.e., there is no shoulder under their heads. It’s important to put the two screws with no shoulder at the hinge of the cover.
All ten screws require a P5 Pentalobe screwdriver, preferably with a magnetized tip to help hold and position the screw.
All of the screws have blue “Loctite” thread locker compound on their threads. This is to help prevent the screws from working loose and falling out. Don’t attempt to clean the Loctite from the screws — leave it in place, and it will continue to help prevent the re-inserted screws from working loose.
When replacing the bottom cover, it is a good technique to insert and BEGIN tightening all ten screws BEFORE fully tightening any one screw. After all the screws have been started, then go around and finish tightening all of them. By doing this, you make it easier to feel that each screw has been started properly, and is not “cross-threaded”.
doubleclutch - Reply
This is what I found on my MBP mid-2014 13” Retina. All 10 used the same screwdriver. I didn’t see the blue “loctite” but I also got my computer refurbished.
Evan Shulman -
A good technique for starting to thread the screws when replacing them is to position and align the screw, and with the driver, gently turn the screw in the REMOVAL direction until you feel and hear a slight click. This click happens when the leading thread of the screw drops off of the leading edge of the thread in the hole — this is the point at which the threads are properly positioned for engagement. You can now turn the driver and screw in the TIGHTENING direction. This technique will help prevent accidental “cross-threading” of the screw, which will damage the threads permanently.
Note that this is a useful technique when installing ANY threaded fastener.
Just finished replacing my battery (MacBook Pro 13” early 2015), glad I did, the old ones were noticeably swollen. I was surprised to find the battery at 57% upon completion and charging the new battery. No problems with replacement however, kit arrived without the Pentalobe driver. I got a nice complete kit from Amazon for 20 euro in 2 days. iFixit offered a coupon on any future purchase but right now, I have no plans on needing anything. Nice gesture but would have preferred the driver in the kit in the first place.
Suggest having a small can of compressed air on hand to clean out the interior, after 4 years, mine was quite dirty. Ear buds and alcohol were the best I could do. And a magnetized driver is mandatory I think.
D M - Reply
REQUIRED PARTS (SCREWS) TO DO THIS JOB UNAVAILABLE HERE:
If your keyboard is riveted to the chassis as mine is, Late 2013 MBP 13” retina, you need about 100 screws to reattach the new keyboard.
ifixit does not have them. I did just now find them at Beetstech for $4.50 along with a back light $13 for the keyboard in case you want one. It looks like Beetstech is a big competitor of ifixit with an excellent reputation (like ifixit has) too. I just ordered these parts and will not happily be moving forward with my keyboard replacement.
Timothy Hardman - Reply
Fun Fact: I got three of the 2,3 mm Pentalopes … ;-)
Paco Demant - Reply
My PB had eight (8), 2.3 mm screws and two (2), 3.0 mm screws.
ellamama - Reply
Hi peeps,
I have a wifi problem on this MBP 13” early 2015 and was pleasently surprised to find your guide to changing the airport card.
However upon closer inspection it seems that on my MBP (purchased new or so I thought) the 3 antennae seem so have been soldered together at the point where they are clamped to the chassis. I have photos but cannot post here. Can anyone conform that where the 3 antennae wires are held to the chssis by the 2 scew metal support (just before disappearing into the screen hinge), the support is not meant to short the 3 wires together. This makes no sense for 3 seperate antennae wires.
Any advice /close up photos is welcome here.
dom
colonel mustard - Reply
Tip: Use post-it notes to keep track of screws
1. Pack of post it notes
2. Stick screws to the sticky part of the post it note
3. Write on the post it note which step and what kind of screw it is
ibash - Reply
Hi, in order to drain the battery I am running:
yes > /dev/null
in 4 terminals, so the CPU maxes out at almost 99%.
I hope this speeds up the battery draining process.
And the backlight is at maximum brightness :-)
You can see the cpu load in Activity Monitor.
Its draining at 20% per 15 minutes.
Any concerns about draining the battery in this way?
Andre van der Ham - Reply
Something I’ve been curious about, is it possible to upgrade a late 2013 Retina model MacBook Pro, with the improved 16gb ram and i7 processor logic board from the 2015 retina model? I’d be interested to try but not ready to shell out the $500+ to be the first lol
Chat Dawgie - Reply
The batteries of my MBP 13” (early 2015) were distended. due to outgassing. They are 3,5 years old but only had 340 cycles. I suppose that the batteries age faster when your computer is permanently plugged in.
When unscrewing the bottom lid, I didn’t have to exert any force to remove the lid as it already popped loose due to the expanded batteries.
Olivier Biot - Reply
By the way, on my pentalobe bit it reads 1.2 instead of P5.
