MacBook Pro 13" Retina Display Late 2012 AirPort Board Assembly Replacement
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. MacBook Pro 13" Retina Display Late 2012 AirPort Board Assembly Replacement, AirPort Board Assembly: step 1, image 1 of 1
    • Remove the single 2.7 mm T5 Torx screw securing the AirPort board to the I/O board.
  2. MacBook Pro 13" Retina Display Late 2012 AirPort Board Assembly Replacement: step 2, image 1 of 3 MacBook Pro 13" Retina Display Late 2012 AirPort Board Assembly Replacement: step 2, image 2 of 3 MacBook Pro 13" Retina Display Late 2012 AirPort Board Assembly Replacement: step 2, image 3 of 3
    • Use the flat end of a spudger to pry and disconnect the three antenna cable connectors from the AirPort board.
    • The three cables are coded with black sleeves of different lengths. During reassembly:
    • Connect the long-sleeved cable to the center socket.
    • The short-sleeved cable connects next to the screw.
    • The remaining cable has no sleeve, and connects in the last empty socket, next to the fan.
  3. MacBook Pro 13" Retina Display Late 2012 AirPort Board Assembly Replacement: step 3, image 1 of 2 MacBook Pro 13" Retina Display Late 2012 AirPort Board Assembly Replacement: step 3, image 2 of 2
    • Move the antenna cables aside, clear of the AirPort board.
  4. MacBook Pro 13" Retina Display Late 2012 AirPort Board Assembly Replacement: step 4, image 1 of 2 MacBook Pro 13" Retina Display Late 2012 AirPort Board Assembly Replacement: step 4, image 2 of 2
    • Pull the AirPort board straight out of its socket on the I/O board.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 41
