MacBook Pro 13" Retina Display Early 2013 Battery Replacement (Legacy)
Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
  1. MacBook Pro 13" Retina Display Early 2013 Battery Replacement (Legacy), Lower Case: step 1, image 1 of 1
    Tool used on this step:
    Magnetic Project Mat
    $19.95
    Buy
    • Two 2.3 mm P5 Pentalobe screws
    • Eight 3.0 mm P5 Pentalobe screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
  2. MacBook Pro 13" Retina Display Early 2013 Battery Replacement (Legacy): step 2, image 1 of 1
    • Wedge your fingers between the upper case and the lower case.
    • Gently pull the lower case away from the upper case.
  3. MacBook Pro 13" Retina Display Early 2013 Battery Replacement (Legacy): step 3, image 1 of 3 MacBook Pro 13" Retina Display Early 2013 Battery Replacement (Legacy): step 3, image 2 of 3 MacBook Pro 13" Retina Display Early 2013 Battery Replacement (Legacy): step 3, image 3 of 3
    • During reassembly, gently push down the center of the lower case to reattach the two plastic clips.
    • The lower case is connected to the upper case at the center, with two plastic clips.
  4. MacBook Pro 13" Retina Display Early 2013 Battery Replacement (Legacy), Battery Connector: step 4, image 1 of 1
    • Remove the plastic cover adhered to the battery contact board.
  5. MacBook Pro 13" Retina Display Early 2013 Battery Replacement (Legacy): step 5, image 1 of 1
    • Remove the following screws securing the battery connector board to the logic board:
    • Two 2.8 mm T6 Torx screws
    • One 7.0 mm T6 Torx shouldered screw
  6. MacBook Pro 13" Retina Display Early 2013 Battery Replacement (Legacy): step 6, image 1 of 2 MacBook Pro 13" Retina Display Early 2013 Battery Replacement (Legacy): step 6, image 2 of 2
    • Use tweezers to remove the small plastic cover located near the bottom right of the battery connector board.
  7. MacBook Pro 13" Retina Display Early 2013 Battery Replacement (Legacy): step 7, image 1 of 1
    • Remove the wide head 6.4 mm T6 Torx screw securing the battery connector to the logic board assembly.
  8. MacBook Pro 13" Retina Display Early 2013 Battery Replacement (Legacy): step 8, image 1 of 2 MacBook Pro 13" Retina Display Early 2013 Battery Replacement (Legacy): step 8, image 2 of 2
    • Carefully lift the battery connector board up off the logic board.
    • It is recommended to bend the battery cables just slightly, to keep the board suspended up above the logic board and out of the way.
    • Do not fold the board completely over, or crease the cables, as this may damage the battery.
  9. MacBook Pro 13" Retina Display Early 2013 Battery Replacement (Legacy), Battery Contact Board: step 9, image 1 of 2 MacBook Pro 13" Retina Display Early 2013 Battery Replacement (Legacy), Battery Contact Board: step 9, image 2 of 2
    • Grasp the Interposer with tweezers.
    • An interposer is the name for an interface that links one electrical connection to another. In this repair, it is the board connecting the battery to logic board.
    • Lift the Interposer off the logic board and remove it.
    • Removing this board will ensure that the battery remains disconnected throughout your repair, preventing your computer from accidentally powering on. It's also a good idea to take it out so it doesn't fall out unexpectedly.
  10. MacBook Pro 13" Retina Display Early 2013 Battery Replacement (Legacy), I/O Board Data Cable: step 10, image 1 of 2 MacBook Pro 13" Retina Display Early 2013 Battery Replacement (Legacy), I/O Board Data Cable: step 10, image 2 of 2
    • Use the flat end of a spudger to pry the right side of the I/O board data cable connector up off its socket on the I/O board.
    • When prying the I/O board data cable connector from its socket, make sure to pry the connector itself and not the socket. Prying the socket may cause irreversible damage to the I/O board.
  11. MacBook Pro 13" Retina Display Early 2013 Battery Replacement (Legacy): step 11, image 1 of 2 MacBook Pro 13" Retina Display Early 2013 Battery Replacement (Legacy): step 11, image 2 of 2
    • Wedge the flat end of a spudger beneath the left side of the I/O board data cable connector.
    • Gently twist the spudger to disconnect the I/O board data cable connector from its socket on the logic board.
  12. MacBook Pro 13" Retina Display Early 2013 Battery Replacement (Legacy): step 12, image 1 of 1
    • Lift and remove the I/O board data cable from the MacBook Pro.
  13. MacBook Pro 13" Retina Display Early 2013 Battery Replacement (Legacy), Right Speaker: step 13, image 1 of 3 MacBook Pro 13" Retina Display Early 2013 Battery Replacement (Legacy), Right Speaker: step 13, image 2 of 3 MacBook Pro 13" Retina Display Early 2013 Battery Replacement (Legacy), Right Speaker: step 13, image 3 of 3
    • Use the flat end of a spudger to pry the SSD cable connector up from its socket on the logic board.
    • Move the SSD cable connector out of the way.
  14. MacBook Pro 13" Retina Display Early 2013 Battery Replacement (Legacy): step 14, image 1 of 2 MacBook Pro 13" Retina Display Early 2013 Battery Replacement (Legacy): step 14, image 2 of 2
    • Wedge the pointed end of a spudger beneath the right speaker cable connector.
    • Gently pry the right speaker cable connector up off from its socket on the logic board.
    • Be sure you are prying up on the connector, not the socket itself.
  15. MacBook Pro 13" Retina Display Early 2013 Battery Replacement (Legacy): step 15, image 1 of 2 MacBook Pro 13" Retina Display Early 2013 Battery Replacement (Legacy): step 15, image 2 of 2
    • Use a T5 Torx driver to remove the following screws securing the right speaker to the upper case:
    • One black 6.8 mm screw
    • One silver 6.3 mm screw
    • One black 4.9 mm screw
    • The silver screw (in the corner) may be covered with a foam pad. If so, use your tweezers to peel it up and remove it.
  16. MacBook Pro 13" Retina Display Early 2013 Battery Replacement (Legacy): step 16, image 1 of 2 MacBook Pro 13" Retina Display Early 2013 Battery Replacement (Legacy): step 16, image 2 of 2
    • Lift and remove the right speaker out of the upper case.
    • If necessary, de-route the right speaker cable from its channel in the upper case.
  17. MacBook Pro 13" Retina Display Early 2013 Battery Replacement (Legacy), Left Speaker: step 17, image 1 of 3 MacBook Pro 13" Retina Display Early 2013 Battery Replacement (Legacy), Left Speaker: step 17, image 2 of 3 MacBook Pro 13" Retina Display Early 2013 Battery Replacement (Legacy), Left Speaker: step 17, image 3 of 3
    • Use the flat end of a spudger to pry the headphone jack cable connector straight up off its socket on the logic board.
    • Gently bend the headphone jack cable to 90° up from the logic board.
    • Bending the headphone jack cable will allow you to disconnect the left speaker cable connector without having the headphone jack cable in the way.
  18. MacBook Pro 13" Retina Display Early 2013 Battery Replacement (Legacy): step 18, image 1 of 2 MacBook Pro 13" Retina Display Early 2013 Battery Replacement (Legacy): step 18, image 2 of 2
    • Wedge the tip of a spudger beneath the left speaker cable connector.
    • Gently pry the left speaker cable connector up off from its socket on the logic board.
  19. MacBook Pro 13" Retina Display Early 2013 Battery Replacement (Legacy): step 19, image 1 of 1
    • Use a T5 Torx driver to remove the following screws securing the left speaker to the upper case:
  20. MacBook Pro 13" Retina Display Early 2013 Battery Replacement (Legacy): step 20, image 1 of 2 MacBook Pro 13" Retina Display Early 2013 Battery Replacement (Legacy): step 20, image 2 of 2
    • Lift and remove the left speaker out of the upper case.
  21. MacBook Pro 13" Retina Display Early 2013 Battery Replacement (Legacy), SSD Assembly: step 21, image 1 of 3 MacBook Pro 13" Retina Display Early 2013 Battery Replacement (Legacy), SSD Assembly: step 21, image 2 of 3 MacBook Pro 13" Retina Display Early 2013 Battery Replacement (Legacy), SSD Assembly: step 21, image 3 of 3
    • Use your thumb or finger to bend the plastic spring bar on the SSD tray, freeing the two clips at the front side of the device.
    • While holding the spring bar depressed, tilt the SSD assembly up out of its cavity.
  22. MacBook Pro 13" Retina Display Early 2013 Battery Replacement (Legacy): step 22, image 1 of 1
    • Remove the SSD assembly from the upper case.
  23. MacBook Pro 13" Retina Display Early 2013 Battery Replacement (Legacy), Battery: step 23, image 1 of 2 MacBook Pro 13" Retina Display Early 2013 Battery Replacement (Legacy), Battery: step 23, image 2 of 2
    • Remove three 2.2 mm T5 Torx screws from each side of the battery (six screws total).
  24. MacBook Pro 13" Retina Display Early 2013 Battery Replacement (Legacy): step 24, image 1 of 1
    • The liquid adhesive remover provided in your kit can affect the antireflective coating on your MacBook Pro's display.
    • To protect your display, place a sheet of aluminum foil between the display and keyboard and leave it there while you work.
  25. MacBook Pro 13" Retina Display Early 2013 Battery Replacement (Legacy): step 25, image 1 of 2 MacBook Pro 13" Retina Display Early 2013 Battery Replacement (Legacy): step 25, image 2 of 2
    • Now that your MacBook Pro is fully prepped, it's time to prep yourself.
    • iFixit adhesive remover contains acetone, a mild skin and eye irritant.
    • Wear eye protection when handling and applying the adhesive remover. (Eye protection is included in your kit.)
    • Do not wear contact lenses without eye protection.
    • Protective gloves are also included in your kit. If you are concerned about skin irritation, put your gloves on now.
  26. MacBook Pro 13" Retina Display Early 2013 Battery Replacement (Legacy): step 26, image 1 of 2 MacBook Pro 13" Retina Display Early 2013 Battery Replacement (Legacy): step 26, image 2 of 2
    • Open your container of adhesive remover.
    • Fill the syringe included in your kit with a small amount (approximately 1-2 milliliters) of adhesive remover.
    • It's best to fill the syringe with no more than about 1-2 milliliters of adhesive remover at a time, so as to avoid accidentally applying too much.
    • Refill your syringe as needed throughout the rest of this procedure.
  27. MacBook Pro 13" Retina Display Early 2013 Battery Replacement (Legacy): step 27, image 1 of 1
    • Apply a small amount of adhesive remover (approximately 1 ml) evenly under the edge of the leftmost battery cell.
    • Wait 2-3 minutes for the liquid adhesive remover to penetrate underneath the battery cell before you proceed to the next step.
  28. MacBook Pro 13" Retina Display Early 2013 Battery Replacement (Legacy): step 28, image 1 of 3 MacBook Pro 13" Retina Display Early 2013 Battery Replacement (Legacy): step 28, image 2 of 3 MacBook Pro 13" Retina Display Early 2013 Battery Replacement (Legacy): step 28, image 3 of 3
    Plastic Cards
    $2.99
    Buy
    • Insert the flat edge of a spudger or plastic card underneath the leftmost battery cell.
    • Run your tool along the bottom perimeter of the battery cell and lift to begin separating the adhesive.
  29. MacBook Pro 13" Retina Display Early 2013 Battery Replacement (Legacy): step 29, image 1 of 3 MacBook Pro 13" Retina Display Early 2013 Battery Replacement (Legacy): step 29, image 2 of 3 MacBook Pro 13" Retina Display Early 2013 Battery Replacement (Legacy): step 29, image 3 of 3
    • Insert the spudger along the left-hand side of the leftmost battery cell.
    • Run the spudger up along the left side of the leftmost battery cell.
    • Slightly pry the leftmost battery cell to release it from the adhesive.
  30. MacBook Pro 13" Retina Display Early 2013 Battery Replacement (Legacy): step 30, image 1 of 3 MacBook Pro 13" Retina Display Early 2013 Battery Replacement (Legacy): step 30, image 2 of 3 MacBook Pro 13" Retina Display Early 2013 Battery Replacement (Legacy): step 30, image 3 of 3
    • Repeat the above steps to separate the adjacent battery cell from its adhesive:
    • Apply a small amount (about 1 ml) of liquid adhesive remover under the battery cell.
    • Wait 2-3 minutes for the adhesive remover to penetrate and soften the adhesive.
    • Carefully wedge a spudger or plastic card inwards, being careful to not damage the battery, and separate the battery cell from the adhesive securing it to your MacBook Pro.
  31. MacBook Pro 13" Retina Display Early 2013 Battery Replacement (Legacy): step 31, image 1 of 3 MacBook Pro 13" Retina Display Early 2013 Battery Replacement (Legacy): step 31, image 2 of 3 MacBook Pro 13" Retina Display Early 2013 Battery Replacement (Legacy): step 31, image 3 of 3
    • Insert the flat end of a spudger underneath the larger leftmost battery cell.
    • Carefully wedge the spudger inwards, being careful to not damage the battery cells.
    • Pry the larger leftmost battery cell up off the upper case.
  32. MacBook Pro 13" Retina Display Early 2013 Battery Replacement (Legacy): step 32, image 1 of 3 MacBook Pro 13" Retina Display Early 2013 Battery Replacement (Legacy): step 32, image 2 of 3 MacBook Pro 13" Retina Display Early 2013 Battery Replacement (Legacy): step 32, image 3 of 3
    • Grasp the battery cells and gently move (but do not remove) them from their recess in the upper case.
    • Leave the battery cells resting on top of the upper case as shown in the third picture.
  33. MacBook Pro 13" Retina Display Early 2013 Battery Replacement (Legacy): step 33, image 1 of 3 MacBook Pro 13" Retina Display Early 2013 Battery Replacement (Legacy): step 33, image 2 of 3 MacBook Pro 13" Retina Display Early 2013 Battery Replacement (Legacy): step 33, image 3 of 3
    • Switch sides and repeat the above procedure for the two battery cells on the right-hand side of the MacBook Pro.
    • Remember to add about 1 ml of liquid adhesive remover under each battery cell, and wait 2-3 minutes for it to penetrate before prying up the cell.
    • Be careful not to puncture or otherwise damage the battery cells.
  34. MacBook Pro 13" Retina Display Early 2013 Battery Replacement (Legacy): step 34, image 1 of 3 MacBook Pro 13" Retina Display Early 2013 Battery Replacement (Legacy): step 34, image 2 of 3 MacBook Pro 13" Retina Display Early 2013 Battery Replacement (Legacy): step 34, image 3 of 3
    • Lift the battery as a whole up out of the upper case, and remove the battery.
    • Before installing a new battery, remove all the old adhesive from the MacBook Pro's case.
    • With a little luck, you can slowly pull out each strip of adhesive with your fingers.
    • Otherwise, soak each section of adhesive with a bit of adhesive remover for 2-3 minutes, and then scrape it out with an opening pick or one of the other tools in your kit. This can take quite a bit of work, so be patient.
    • Mop up any remaining adhesive remover and give your MacBook Pro a few minutes to air dry.
    • The replacement battery included in your iFixit kit comes with adhesive pre-installed. Test the battery's fit and alignment carefully before peeling off the film covering the adhesive, and then press each cell firmly into place. If any additional films/liners are present that weren't on your original battery, remove them now.
    • Calibrate your new battery before using it: allow it to drain overnight, then charge it to 100% and drain it again until your MacBook Pro shuts down automatically. Charge it again and use it normally.
    • If you notice any unusual behavior or problems after installing your new battery, you may need to reset your MacBook Pro's SMC.
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 405
