Introduction
使用这个指南来帮助你更换 MacBook Pro(15英寸,带有视网膜显示屏,2015年中期)所安装的SSD(固态硬盘)。 这个MacBook Pro使用特制的硬盘接口,所以在不使用转接器的情况下无法与使用M.2的接口的硬盘兼容。
在你开始所有操作之前,请在允许的情况下备份你现有的SSD中的所有数据。之后,请确保你熟悉通过网络恢复设备或者创建一个外置的便携启动硬盘。这样你就可以将 macOS 安装到新驱动器上,并将数据迁移到新 SSD。
最后了,我们强烈建议在更换MacBook Pro现有的SSD前安装macOS 10.14 Mojave (或者更新版本的macOS)操作系统。大多数新的SSD需要更新的驱动,是macOS 10.14 Mojave前的老版本的macOS中所没有的。
要重新组装你的设备,请按本指南的逆序操作。
293 other people completed this guide.
Special thanks to these translators:
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
82 Comments
So guys, I got a couple of questions:
1. Is this model (MBP Retina Mid 2015/MacBookPro11,4 ) really upgradable? https://www.datenreise.de/en/macbook-pro... says otherwise.
2. Samsung 850 EVO or Samsung 850 PRO would work with the model mentioned above?
Yes, it is upgradeable. At the time that article was published there was no drive on the market that would work. Now there is. No the Samsung 850 EVO or Pro would not work. As far as I know OWC is the only one that produces an after market drive that is compatible.
I couldn't find the SSD that Chris mentioned. Would you please point out the exact model?
It’s the OWC Aura Pro X2, you can get it all the up to 2TB.
