Introduction
Der Austausch des RAM ist einfach, der Computer braucht dazu nicht geöffnet zu werden. Es gibt zwei Einschübe, in die maximal 2 GB von PC2-5300 RAMs eingesetzt werden können.
Drehe die Verschlussschraube des Akkus mit einer Münze oder einem Spudger um 90° im Uhrzeigersinn.
An der Rückwand des Akkufachs befinden sich im gleichen Abstand drei Kreuzschlitzschrauben. Drehe sie heraus.
Bewege die Hebel in einer schnellen, aber vorsichtigen Bewegung nach links und hole den RAM-Chip aus dem Einschub heraus.
Um dein Gerät wieder zusammenbauen, folge den Schritten in umgekehrter Reihenfolge.
127 other people completed this guide.
Special thanks to these translators:
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
5 Comments
I followed these direction to upgrade my ram from 2 512MB chips to 2 1GB chips. They were simple, but I hit a snag somewhere because when I went to turn back on my computer the light on the slide just blinked several times and no start up ocurred. How do you know that the new RAM chips are in sufficiently? Do you have to press them in until they click or lock? Mine just slid in and are somewhat "loose" still.
thanks!
Madeline I have the same question about re inserting the ram but can't find an answer
did you?
Hank
hlsilvia@flhi.org
hank1930 -
I don't know why some people are mentioning a torx. This is a regular phillips. Had one laying around from my old-style mac mini upgrade. It couldn't be easier. It's almost like the new style mac mini ram upgrade. So effortless.
Please note. The ram modules have to be pushed all the way in until they click in place. You have to push them quite hard to do this. If the ram modules just slide in until they stop then they won’t make contact.
