Introduction
Use this guide to replace your audio cable.
Remove ten Phillips screws securing the lower case to the MacBook Air:
Six 2.8 mm screws
Two 3.8 mm screws
Two 5.4 mm screws
Lift the battery out of the Air.
Charge it to 100%, and then keep charging it for at least 2 more hours. Then, unplug and use it normally to drain the battery. When you see the low battery warning, save your work, and keep your laptop on until it goes to sleep due to low battery. Wait at least 5 hours, then charge your laptop uninterrupted to 100%.
If you notice any unusual behavior or problems after installing your new battery, you may need to reset your MacBook's SMC.
Remove the following two screws securing the speaker assembly to the upper case.
One 3 mm Phillips.
One 5.8 mm Phillips.
Disconnect the port hatch ribbon cable from the logic board by pulling it straight up by its black pull tab.
If necessary, pull the audio out ribbon cable off the adhesive securing it to the upper case.
Lift the hard drive slightly and use a spudger to pry the audio cable connector up off the logic board.
Peel the audio cable off the adhesive securing it to the upper case.
94 other people completed this guide.
7 Comments
It's perfect guide. I had a same situaton with my Air and cable that I ordered from here works perfect.
Thanks
I had no audio, with the sound icon in menu bar absent and volume panel grayed out. This repair worked! Be sure to label each screw type from each step of the guide (some screws that were supposed to be same mm from two different steps were not). Be careful not to strip screws when removing them, and not to cross-thread when reinserting. Thanks for the guide.
It works , easy to follow guide and super fast shipping of the cable (just 6days), thanks guys ! BRGDS from Spain
Can i use it with a MacBook Air mid 2011?
The socket for the audio cable in my Mac is broken. Can I replace it? What is it called? Thankyou!!
