Introduction
Use this guide to replace a faulty trackpad in a Late 2020 MacBook Air (M1).
Tool used on this step:Magnetic Project Mat$19.95
If your MacBook is running Big Sur v11.1 or later, disabling Auto Boot may not work. You can proceed normally, but make sure to disconnect the battery as soon as you're inside.
Use a P5 driver to remove the following screws:
Two 7.9 mm screws
Two 7.3 mm screws
Six 2.6 mm screws
Wedge your fingers between the display and the lower case and pull upward to pop off the lower case.
Remove the lower case.
Set it in place and press firmly to engage the two hidden clips underneath. You should feel and hear them snap into place.
Use the flat end of a spudger to pry up and unlatch the metal locking arm on the battery connector.
Lift straight up on the metal locking arm to pull the battery connector out of its socket on the logic board.
If necessary, push the rear, wire side of the connector into place first, then rock the front of the connector into place.
If having difficulty in flipping the bar up, place the machine vertical and not that there is a small “locking nib” that the bar has to clear. You may have to give the bar honest persuasion to clear the nib.
The bar can lock backwards making it very hard to even see let alone move. Great care is needed to shift it. I had to use two thumbnails, one on each side, then once flipped forward it takes more push than I expected to clip it in place. Ensure the plug is fully seated first !
Use a T3 Torx driver to remove the two 1.4 mm screws securing the trackpad cable cover.
Use the flat end of a spudger to pry the trackpad cable connector up and out of its socket.
Use a pair of tweezers to peel back the tape covering the trackpad cable connector.
Use the pointed end of a spudger to lift up the small locking flap on the trackpad cable's ZIF connector.
Use a T5 Torx driver to remove the nine screws securing the trackpad:
Eight fully-coated 3.1 mm screws
One partially-coated 3.1 mm screw
While keeping the laptop screen-side down, carefully open the laptop. The trackpad will stay sitting on the display.
As you remove the trackpad assembly, be careful not to lose the five small metal washers resting on the screw posts. (They will fly off and get lost with very little provocation.)
Remove the trackpad.
Yes, watch out for those little spacers. They are silver and blend right in with the bottom of the trackpad until you turn it upside down.
Anyone know where to find replacement washers? I lost mine and can't find a source online. The trackpad doesn't click very well without them.
Use the flat end of a spudger to lift the small locking flap on the trackpad's ZIF connector.
Slide the trackpad cable straight out of the ZIF connector.
Once you've completed your repair, your laptop may not power back on until connected to power.
9 other people completed this guide.
12 Comments
Hi! So I successfully replaced my trackpad (the center screw got stripped so I had to use the superglue technique and threw it away), and the trackpad works perfectly well but without haptics. My replacement didn’t come with a new cable so used the old one after cleaning of the end (it had some blackening on the portion connected to the trackpad). Is my trackpad a bad unit or should I try replacing the cable first?
Hi! Considering the blackening on the old cable, I’d recommend thoroughly cleaning its contacts with high concentration (90%+) isopropyl alcohol and a Q-tip. Let it dry before reinstalling it. If that cleaning doesn’t help, replace the old cable before considering your replacement trackpad a bad unit. Good luck on your repair!
Hi Carsten! I tried cleaning it but didn’t work. Picked up a new cable from here, and now works flawlessly. Highly recommend anyone reading this to just buy a replacement cable too when you do the repair to rule out a faulty part. Thanks!
Hi, I replaced trackpad following the guide and trackpad seems to work but very slow and lagging. and when I log in, mac is showing message waiting for bluetooth trackpad to be discovered. Could this be cable issue?
Hi team,
I follow this guide to replace my trackpad and now strangely my “a” and “d” keys no longer work on my keyboard. Any thoughts on how this could have happened?
Cheers
Zac,
Check that the cables you disconnected during the repair are fully seated in their ZIF connectors. You could also check surrounding cables to ensure all look normal, that none are inserted at odd angles, etc.
Good luck!
I am having the exact same issue. Were you able to figure it out?
I have a custom configuration M1 MacBook Pro 13” Late 2020, and sadly this is not the same system. My system has two fewer screws on the top, and no screws on the sides. Opening it, the layout of things and the types of connectors also differ. Any recommendations on what is wrong here?
This is the guide for the Late 2020 MacBook Air. Sounds like you have a MacBook Pro of the same year — here's that trackpad guide!
Hello, I replaced the trackpad but now macbook air won't turn on. Any thoughts? I checked the battery connector already.
- Figured it out. I plugged in the charger in, and macbook air powered on.
The track pad works great. Thank you. Instructions were easy to follow.
Please note that if you're here looking at this due to water damage, you can try some simpler things first.
My wife spilled water on the keyboard/trackpad and did not turn the laptop off, just let it sleep. It was not much water and it was just water - not coffee, soda, etc., so YMMV. I took the whole thing apart, removed the trackpad (using this guide), and removed all the connectors between the trackpad and everything else. I dried laptop with a hair dryer with the back off and the trackpad out - maybe about 5 minutes moving around the keyboard area front/back and a bit around the logic board. I used some IPA all over the connectors and cables and let that dry. I reassembled the laptop and on first boot, it was acting odd - every touch of the trackpad resulted in a click. I shut the laptop down (there's no PRAM/SMC on an M1, so power cycle is the option here) and it now works fine. I'm also now letting it sit in an oven at 130F (heated to 200F - lowest setting, then let the oven cool to 130F). So far so good
ESD safe mat, plugged into ground, with a wrist strap, also grounded, are the best best to protect the logic board.
Robin Ray - Reply
Re-Assembly Tip: Before putting the screws back in, snap the lower case on and test to make sure the MacBook powers up. When I first re-assembled, I became very nervous I did something wrong because it would not power on. It turns out I just needed to plug the laptop into a power source for it to power up (despite having a good charge before disassembly). It was the perfect way to test the new USB-C ports!
Austin - Reply
Big points to this one, especially for mentioning needing to plug the laptop in. The bottom case needs to be screwed in and laptop needs to be plugged in before it will boot.
Bayden Yazalina -
Wiha 4PL driver for these screws.
Greg Worrel - Reply
Printing out all the images from this Ifixit guide prior to starting and using duct tape help me keep track of screws.
raju midjdeya - Reply
