Introduction
Use this guide to replace your MacBook Air's display assembly.
Tool used on this step:P5 Pentalobe Screwdriver Retina MacBook Pro and Air$5.99
Remove the following ten screws:
Two 9 mm 5-point Pentalobe screws
Eight 2.6 mm 5-point Pentalobe screws
Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
Remove the lower case and set it aside.
Grab the clear plastic pull tab attached to the battery connector and pull it toward the front edge of the Air to disconnect the battery from the logic board.
Use the flat end of a spudger to pry the I/O board cable connector upward out of its socket on the I/O board.
Carefully peel the I/O board cable from the top of the fan.
While gently pulling the I/O board cable upward near its connection to the logic board, use the tip of a spudger to pry upward on alternating sides of the connector to help "walk" it out of its socket.
Remove the I/O board cable.
Use the tip of a spudger to carefully flip up the retaining flap on the fan cable ZIF socket.
Remove the following three screws securing the fan to the upper case:
One 3.6 mm T5 Torx screw
One 2.7 mm T5 Torx screw
One 3.6 mm T5 Torx screw with a short head
Lift the fan out of the upper case and carefully pull the fan ribbon cable out of its socket as you remove it from the Air.
Disconnect the I/O board by pulling the power cable away from its socket on the logic board.
Pull the camera cable parallel to the face of the I/O board toward the corner of the Air to disconnect it from its socket, using the tip of a spudger to help push the connector out of its socket.
Use the flat end of a spudger to pry the left speaker cable connector up and out of its socket on the I/O board.
De-route the left speaker cable from its retainer on the I/O board.
Use the flat end of a spudger to pry the microphone cable connector up and out of its socket on the I/O board.
Carefully lift the I/O board from its edge nearest the logic board and remove it from the upper case.
Remove the following five screws securing the battery to the upper case:
Three 6.3 mm T5 Torx screws
Two 2.4 mm T5 Torx screws
Use the tip of a spudger or your fingernail to flip up the retaining flap on the trackpad ribbon cable ZIF socket.
Pull the trackpad ribbon cable straight out of its socket toward the front edge of the Air.
Use the flat end of a spudger to pry the right speaker cable connector up and out of its socket on the logic board.
Gently push the tip of a spudger under the black plastic flap stuck to the display data cable lock to make the lock pop upward and away from the socket.
While holding the lock away from the socket, use the tip of a spudger and your fingers to gently remove the display data cable from its socket by sliding it toward the corner of the Air.
Use the flat end of a spudger to pry both antenna cable connectors up and off their sockets on the AirPort/Bluetooth card.
Remove the inner two 4.9 mm T8 Torx screws securing the antenna cable retainer and left clutch hinge to the upper case.
Push the antenna cable retainer away slightly and remove the 3 mm T5 Torx screw securing the end of the heat sink to the upper case.
Carefully remove the logic board assembly from the upper case, minding any cables that may get caught.
Gently de-route the antenna cables out of the channel cut into the upper case.
Remove the inner two 4.9 mm T8 Torx screws securing the right display hinge to the upper case.
Open the display until it is perpendicular to the upper case and place it on a table as shown.
While holding the Air steady, remove the remaining 4.9 mm T8 Torx screw from the lower display bracket.
Push the upper case slightly toward the display assembly, then rotate it away from the front of the display assembly.
Once the two display hinges have cleared the upper case, remove the display and set it aside.
