MacBook Air 11" Mid 2013 Logic Board Assembly Replacement
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. MacBook Air 11" Mid 2013 Logic Board Assembly Replacement, Logic Board Assembly: step 1, image 1 of 3 MacBook Air 11" Mid 2013 Logic Board Assembly Replacement, Logic Board Assembly: step 1, image 2 of 3 MacBook Air 11" Mid 2013 Logic Board Assembly Replacement, Logic Board Assembly: step 1, image 3 of 3
    • Use the flat end of a spudger to pry both antenna connectors up from their sockets on the AirPort/Bluetooth card, and move them out of the way.
  2. MacBook Air 11" Mid 2013 Logic Board Assembly Replacement: step 2, image 1 of 1
    • Remove the following five screws securing the battery to the upper case:
    • Two 5.2 mm T5 Torx screws
    • One 6 mm T5 Torx screw
    • Two 2.6 mm T5 Torx screws
  3. MacBook Air 11" Mid 2013 Logic Board Assembly Replacement: step 3, image 1 of 1
    • When handling the battery, avoid squeezing or touching the six exposed lithium polymer cells.
    • Lift the battery from its edge nearest the logic board and remove it from the upper case.
  4. MacBook Air 11" Mid 2013 Logic Board Assembly Replacement: step 4, image 1 of 2 MacBook Air 11" Mid 2013 Logic Board Assembly Replacement: step 4, image 2 of 2
    • Disconnect the I/O board by pulling the power cable away from its socket on the logic board.
    • Pull the cable parallel to the face of the logic board toward the front edge of the Air.
  5. MacBook Air 11" Mid 2013 Logic Board Assembly Replacement: step 5, image 1 of 3 MacBook Air 11" Mid 2013 Logic Board Assembly Replacement: step 5, image 2 of 3 MacBook Air 11" Mid 2013 Logic Board Assembly Replacement: step 5, image 3 of 3
    • Use the tip of a spudger to de-route the antenna cables from their notches in the logic board.
  6. MacBook Air 11" Mid 2013 Logic Board Assembly Replacement: step 6, image 1 of 3 MacBook Air 11" Mid 2013 Logic Board Assembly Replacement: step 6, image 2 of 3 MacBook Air 11" Mid 2013 Logic Board Assembly Replacement: step 6, image 3 of 3
    • Gently push the tip of a spudger under the black plastic flap stuck to the display data cable lock to make the lock pop upward and away from the socket.
    • While holding the lock away from the socket, gently pull the display data cable out of its socket.
    • Do not pull upward on the display data cable as you disconnect it, as its socket may break off the logic board.
  7. MacBook Air 11" Mid 2013 Logic Board Assembly Replacement: step 7, image 1 of 3 MacBook Air 11" Mid 2013 Logic Board Assembly Replacement: step 7, image 2 of 3 MacBook Air 11" Mid 2013 Logic Board Assembly Replacement: step 7, image 3 of 3
    • Use the tip of a spudger to pry under the speaker cable connector, lifting it straight up from its socket.
    • De-route the cable from its notch in the logic board.
  8. MacBook Air 11" Mid 2013 Logic Board Assembly Replacement: step 8, image 1 of 3 MacBook Air 11" Mid 2013 Logic Board Assembly Replacement: step 8, image 2 of 3 MacBook Air 11" Mid 2013 Logic Board Assembly Replacement: step 8, image 3 of 3
    • Use the tip of a spudger or your fingernail to flip up the retaining flap on the trackpad ribbon cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap, not the socket itself.
    • Pull the trackpad ribbon cable straight out of its socket toward the front edge of the Air.
  9. MacBook Air 11" Mid 2013 Logic Board Assembly Replacement: step 9, image 1 of 3 MacBook Air 11" Mid 2013 Logic Board Assembly Replacement: step 9, image 2 of 3 MacBook Air 11" Mid 2013 Logic Board Assembly Replacement: step 9, image 3 of 3
    • Use the tip of a spudger to flip up the retaining flap on the keyboard backlight ribbon cable ZIF socket.
    • Pull the keyboard backlight ribbon cable out of its socket.
  10. MacBook Air 11" Mid 2013 Logic Board Assembly Replacement: step 10, image 1 of 1
    • Remove the single 2.9 mm T5 Torx screw securing the AirPort/Bluetooth card to the logic board.
  11. MacBook Air 11" Mid 2013 Logic Board Assembly Replacement: step 11, image 1 of 3 MacBook Air 11" Mid 2013 Logic Board Assembly Replacement: step 11, image 2 of 3 MacBook Air 11" Mid 2013 Logic Board Assembly Replacement: step 11, image 3 of 3
    • Slightly lift the free end of the AirPort/Bluetooth board and pull it out of its socket on the logic board.
    • To avoid damaging its socket on the logic board, do not excessively lift the free end of the AirPort/Bluetooth card.
  12. MacBook Air 11" Mid 2013 Logic Board Assembly Replacement: step 12, image 1 of 1
    • Remove the three 3.6 mm T5 Torx screws securing the logic board to the upper case.
    • In some models these are 3.1 mm T5 Torx screws.
  13. MacBook Air 11" Mid 2013 Logic Board Assembly Replacement: step 13, image 1 of 3 MacBook Air 11" Mid 2013 Logic Board Assembly Replacement: step 13, image 2 of 3 MacBook Air 11" Mid 2013 Logic Board Assembly Replacement: step 13, image 3 of 3
    • Gently lift the logic board assembly from the heat sink end and pull it away from the port side of the case to remove it from the Air.
    • When replacing the logic board, insert the board's rubber edge under the port-side rubber gasket, then lower the board into place.
Sam Goldheart
465,744 Reputation
538 Guides authored
iFixit Member of iFixit
Staff
135 Members
16,816 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 122
