Replacing MacBook Air 11" Mid 2013 I/O Board Cable
  1. Replacing MacBook Air 11" Mid 2013 I/O Board Cable, Lower Case: step 1, image 1 of 1
    Tool used on this step:
    P5 Pentalobe Screwdriver Retina MacBook Pro and Air
    $5.99
    Buy
    • Shut down and close your computer. Lay it on a soft surface top-side down.
    • Remove the following ten screws:
    • Two 8 mm 5-point Pentalobe screws
    • Eight 2.5 mm 5-point Pentalobe screws
    • The special screwdriver needed to remove the 5-point Pentalobe screws can be found here.
  2. Replacing MacBook Air 11" Mid 2013 I/O Board Cable: step 2, image 1 of 1
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
  3. Replacing MacBook Air 11" Mid 2013 I/O Board Cable, Battery Connector: step 3, image 1 of 2 Replacing MacBook Air 11" Mid 2013 I/O Board Cable, Battery Connector: step 3, image 2 of 2
    • In this step you will disconnect the battery to help avoid shorting out any components during service.
    • Use the flat end of a spudger to pry both short sides of the battery connector upward to disconnect it from its socket on the logic board.
    • Bend the battery cable slightly away from the logic board so the connector will not accidentally bend back and make contact with its socket.
  4. Replacing MacBook Air 11" Mid 2013 I/O Board Cable, I/O Board Cable: step 4, image 1 of 2 Replacing MacBook Air 11" Mid 2013 I/O Board Cable, I/O Board Cable: step 4, image 2 of 2
    • Use the flat end of a spudger to pry the left and right I/O board cable connectors up off their respective sockets on the I/O board.
  5. Replacing MacBook Air 11" Mid 2013 I/O Board Cable: step 5, image 1 of 1
    • Lift and remove the I/O board cable.
Sam Goldheart
465,759 Reputation
538 Guides authored
iFixit Member of iFixit
Staff
135 Members
16,816 Guides authored
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 17
All Time: 2,484
