This translation may not reflect the most recent updates from the source guide. Help update the translation or view the source guide.
Introduction
如果您的MacBook不再保修,或者插入时看不到橙色或绿色充电指示灯,请检查电源线是否有损坏。
在本指南中,我们将更换充电器连接到 MacBook 的线。
或者,您可以使用How to Repair an Apple AC Adapter Broken Cable修复现有的电缆,而不是替换它。
打开绕线小翅膀的电线处。
用吹风机加热电源的塑料外壳,和/或沿外壳的两半之间的接缝移动刀片,以减弱粘合剂。 这样可以更容易地撬开。
插入你的钳子并慢慢撬。 (确保他们保持在内角,否则可能会伤到自己或者捣毁电源。)
绕线小翅膀将调出来
在另一边做同样的步骤。
慢慢操作!
向所有您的朋友申请并重覆有问题的电缆的受害者;-)
180 other people completed this guide.
Special thanks to these translators:
94%
These translators are helping us fix the world! Want to contribute?
Start translating ›
48 Comments
This guide was very helpful in figuring out what needed to be done and how to do it. I don't have access to a lead pump so I ended up removing the old wires and then soldering the new ones on top of the remaining solder. So far it's working just fine!
I wasn't able to open my charger, even when using heat, the pliars as shown here and even a knife. As the damage to my cable was a few inches from the charger I just cut the cord and soldered a new one to the end. Cable looks a bit ratty but you could use white tubing to place over the top.
This guide is great and would definitely use it if possible =)
Try using bench vise with needle-nose plier
ridwan -
You certainly need to knife thoroughly along the seam for it to open; after which you need to pry slowly with a pair of pliers by applying a considerable amount of force. Prudence is necessary when applying force because brute force will likely damage the casing; that means if you think adding more force will break the casing, it probably will. Knife it some more and then try again. Patience is *key*.
nawkwan -
I managed to open the casing without breaking it *but I did break my pliers in the process. lol
nawkwan -
