This translation may not reflect the most recent updates from the source guide. Help update the translation or view the source guide.
Introduction
不要给Apple换电池,自己动手来做!
使用电池上的塑料拉手将电池从顶壳上移走。
在你使用的电池之前先 校准 它:
将其充电至100%,并继续充电至少2小时。拔下电源并正常使用以排空电池。当您看到低电量警告时,请保存您的工作,并保持笔记本电脑一直打开,直到它因电池电量不足而进入睡眠状态。等待至少5个小时,然后不间断地将笔记本电脑充电至100%。
在你安装好你的新电池之后,如果你注意到任何不寻常的举动或是问题,你可能需要重置你MacBook Pro的SMC。
用相反的步骤重新组装的你设备。
用相反的步骤重新组装的你设备。
334 other people completed this guide.
Special thanks to these translators:
88%
These translators are helping us fix the world! Want to contribute?
Start translating ›
37 Comments
I bought a tri wing y1 from Wera, but it was way to big.... I guess I'll buy the ifixit bit set, but otherwise I would try y0.
--edit-- Looking at the photo's here of the tri-wing screws, it more looks like my macbook has different screws. Mine are black and as large as the other normal screws.
Looks like the 2010 version has y0 somehow.
Peterdk -
I just replaced the battery on my late 2009 mac and thanks to this and all the other detailed guides it was actually quite simple (save for those cursed tri-wings). Don't feed apple with money you can spend on better things. A battery-removel isn't one of them.
For those that have questions about the size of the bit, every article starts with "Tools". The tri-wing is size Y1 as the guide says. 5mm is the length of the screw itself, not the size of the bit.
Just replaced a battery myself. The replacement battery (from an ebay seller) is supposed to be genuine, but was missing the "Warning, do not remove the battery" sticker and the "Do not throw in the trash" sticker, and the main sticker was glossy with air bubbles. Not sure if fake or not. But have been working great this first night.
This guide was spot on. Followed every step, and used the iFixit kit when doing the repair.
