Introduction
Replace your audio board to regain functionality of your speakers and microphone.
Parts
No parts specified.
Power down your Mac mini, disconnect all of the cables, and flip it over.
Insert the Jimmy into the crack between the aluminum top housing and the plastic lower housing.
The Jimmy should reach a stop about 3/8" down.
Gently bend the Jimmy outwards to pry the crack open a little larger and lift the lower housing up a small amount.
Once you have the first side free, rotate the Mac mini and start prying up on the front edge.
Use the same prying motion to both bend the clips inward and lift the lower housing up out of the top housing.
You may need to move the Jimmy along the edge to pry up all of the clips. Be patient and do a little bit at a time.
Remove the single Phillips screw between the headphone and microphone jacks on the audio board.
Use the flat end of a spudger to pry the audio ribbon cable connector off the interconnect board.
Use the tip of a spudger to depress the audio board retaining clip (shown in red) to release the audio board from the bottom housing.
Lift the audio board from its free end and remove it from the mini.
